"Code" light?
1 Post
"Code" light?
Hey guys,
As I'm getting closer to doing my own swap (& trying to think of all of the "little stuff" that I'll need to keep track of), I just realized that I hadn't accounted for the "MIL light" (or SES/check engine indicator). I thought I'd ask some of you how you guys handled it with your own conversions, especially in cars that didn't have any provision for them...
Thanks.
Thanks.
Get a little 12v light assy (radio shack) wire it to correct 12v power (can't remember if "hot always" or "hot run-start") other wire goes thru C220 or C230 (also can't remember -- I'm not where the wiring diagrams are) and is turned on/off by the PCM supplying the ground for the light. I used a 5/8" dia light assy, and drilled a little hole for it in an inconspicuous place. You may have an un-used switch or light knock-out on your dash that you could use for this purpose.
