(P/N 713088-P) GM Gen III Vortec engine mount kit
http://72.20.96.178/commerce/ccpc105...p-713088-p.htm
Getting them from summit is $69.95
Dim. look to be the same as the Hookers with extra set of holes, but alot cleaner finished product.
From the looks of it. The adapter can be used in two locations. As the two sets of bolt holes and engine mount relief slot would allow to different setups...by using the extented part forward, it would be like the ATS/Hooker and simular to S&P. By pointing the extented part rearwards, it would be simular to the BRP style mounts.
so.. pick you location on these...
they def look a lot like hookers hole setup, but i wonder why all the people making these mounts go for the flush mount bolts-true you need them under the engine mounts, but where they are exposed, i prefer bolt heads-more tighting torq, and if their tight rem. you dont have to worry about rounding the hole in the bolt out (just my opinion)
