LS1 Rx 7 FC... Front Accesories
Old 12-27-2007, 12:01 PM
Wally5.0's Avatar
Default LS1 Rx 7 FC... Front Accesories
I have an 88 rx 7 I am doing an ls1/t56 swap. The motor is from an 04 gto, it has a crank pulley/balancer but no front accesories. I am am only going to run AC,Water pump(obviously), and an alternator. I will be using the grannys mounts. What do I need to get accesory wise. Will camaro and firebird brackets and accesories work? Or do I need to go with the GTO stuff, I searched but had trouble finding any real answers. I don't have a pcm and harness yet either, I am assuming that may be a factor. But anyway any help would be much appreciated! Thanks guys
Chris
Old 12-27-2007, 04:39 PM
Mr.Hatch's Avatar
Yes the cambird accessories will work - not sure about the GTO.
Search here - http://www.v8rx7forum.com/
Old 12-28-2007, 09:26 AM
Wally5.0's Avatar
Ok thanks, I am on the v8rx7 board too... can't seem to find much by searching. I guess I really just need to figure out if the gto balancer is the same as the cambird?
I see you have an 88 vert, I do too. Got any pics?
Old 12-28-2007, 11:50 AM
digitalsolo's Avatar
I'm pretty sure the GTO uses the same accessory belt offset as the Cam/Bird. The answers you seek are on v8rx7forum.com
Old 12-28-2007, 12:11 PM
rao
rao's Avatar
The GTO offset is the same as the F-body.
Old 12-28-2007, 01:31 PM
Wally5.0's Avatar
Thanks guys!
Old 12-28-2007, 03:56 PM
Mr.Hatch's Avatar
Not any good ones.
Old 12-28-2007, 04:12 PM
rao
rao's Avatar
Brings back memories
https://ls1tech.com/forums/showthrea...638&highlight=
Old 12-29-2007, 11:48 PM
Wally5.0's Avatar
Looks good, thanks for the links!
Quick Reply: LS1 Rx 7 FC... Front Accesories
