5.3 Vortec in older car..... more power...
Hi I have bought a 2006 5.3 Vortec that I plan to have installed into an older car. The guy I got it form have done all the wiring and computer reprogramming of the computer for my axle ratio and tire height. It is also programmed to run on 95 octane. I am planning to install headers and dual 2,5inch exhaust. K&N air filter and electrical fans.
How much power can I expect to have?
And I am also flirting with the thought of how I can make more power in the future.
Lets imagine I`ve got a $2-3000, how can i make the most power with my money? Cam, Heads, Supercharger, Turbo? (And please don`t say put in a 6.0L or nitrous, I`ve got this engine and plan to use it, will get a 6.0 next time, and since I live in Norway theese engine aren`t as easy to find over here)
I would still like to use it on a dayly bases in the summer here in Norway, so I can`t have something too extreme, and would like to have good torque down low as well.
Any Ideas? Thanks
Any Ideas? Thanks
Depending on what you are after, you may find the 5.3 is perfect the way it is. I would fully expect you to exceed 300hp, which is a nice, comfy number. If you want more power after that, MC is right, you need to look at Cam, intake, head-work. Leave some cash on the table for some tuning as well, you can pick up a bit of HP just having the engine tuned. You didn't mention what older car you are using, that will make a big difference on what you should expect on the butt-dyno. That 5.3 will move a 5K lb truck pretty nice, it will really scoot in a 2800lb car.
Going into...
either my fathers 81 Chevrolet Silverado Pick up lightest version with 3,23:1 rearend and 27 inch tall tires, or a 1972 Pontiac LeMans with 3,73:1 rearend and 27 inch tall tires.
