5.3L in a 89' Caprice 9C1
Old 01-05-2008, 11:50 PM
busta9876's Avatar
Default 5.3L in a 89' Caprice 9C1
Just got some of the major work done today on my swap project. 1989 Caprice 9C1 police package car. Long run plans are a single turbo on the stock 5.3L engine. Right now I'm going to put it together NA to see how the motor runs and all.
Transmission is Turbo 400 with a small stall, about 2400-2600 range. Rear axle is 3.42. Should be decently quick with just the 5.3, should be real fun once turbo is on there.
I'm looking for a 8.5" 10bolt posi if anyone has one for 3 series carrier...
Some pics are attached....
Was going to put manifolds on the motor but we had some Hawks Third Gen LS1 long tube headers laying around, and they fit great, Y-Pipe and all, so that save me having to fab up some temporary exhaust. I did have to cut the ear of the side of the TH400 trans on passanger side for long tubes to fit, but no big deal there....
Attached Thumbnails 5.3L in a 89' Caprice 9C1-caprice014.jpg   5.3L in a 89' Caprice 9C1-caprice012.jpg   5.3L in a 89' Caprice 9C1-caprice016.jpg   5.3L in a 89' Caprice 9C1-caprice019.jpg   5.3L in a 89' Caprice 9C1-caprice020.jpg
Old 01-06-2008, 12:20 AM
twisselman1968's Avatar
Thumbs up freakin sweet
hay man looks great are you running one of the harnesses like you made for me on my LS1 I love it keep up the good work can't wait to see some videos of it when it gets done. did you have any oil pan problems?
Old 01-06-2008, 08:46 AM
busta9876's Avatar
using stock modified truck harness on this one,
Oil pan hangs a little low, about 1.5 inche below crossmember...gonna make a skid plate or somthing to protect it...
Old 01-06-2008, 09:30 PM
monteperformance's Avatar
You are using the stock caprice motor mounts? What adapter plates are those? How does everything fit?
Old 01-06-2008, 10:19 PM
busta9876's Avatar
mounts are stock caprice (which are also stock for almost everything GM V8 from the 70's to early 90's. Its the mount bolted to cross member, and clam shell bolted to engine (in this case, I made a set of adaptor's based on the Transdapt version of them. I made them out of aluminum.
I am running into clearance problem with oil pan to cross member and oil pan to the drag link...I may have to move the motor up 1/4 to 1/2 inch.
Old 01-06-2008, 11:23 PM
yah man I'd love to see some pics of the manifolds and the mounts once you get everything lined out
Old 01-07-2008, 08:45 PM
hay man what did you do for a drive shaft did you have a custom one made or what
Old 01-07-2008, 09:54 PM
festo's Avatar
The truck oil pan fit good ?
Any crossmember cut ??
Old 01-07-2008, 10:19 PM
busta9876's Avatar
The drive shaft was stock unit from my 67 chevy pickup, had the TH400 slip yoke and found a U join that fit my drive shaft and the 8.5 inch rear end. At ride height, the drive shaft had about 1/2" travel, and this increased with compression of suspension. However with suspension dropped the drive shaft bottomed out in the trans, so I'm having 3/4" taken out of the length.
Crossmember clears oil pan fine, however steering drag link is very close, and when cutting wheels to the right, the inner tie rod end rubs the oil pan. I will probably raise the motor mounts 1/4" to clear things up.
Old 01-08-2008, 04:46 PM
man I really like this project keep me informed I can't wait to see this thing going
Old 01-09-2008, 02:02 PM
Novas Forever's Avatar
This would be one of my favorite swaps, good job.
Old 01-11-2008, 05:41 PM
KC Henry's Avatar
I can't wait to see another LSX "boxy" Caprice. There needs to be more of us (LSX Caprice's out there !) Any predictions for what it may run the 1320 in while its stock? Keep up the good work!
Old 01-13-2008, 06:39 PM
hay what kind of turbo are you running on it and is it going to be intercooled
Old 01-19-2008, 02:32 PM
busta9876's Avatar
I got a little more work done, its been very cold, under 25 for last week or so, so work has been slow.
Stock caprice TBI wiring removed, only cut 2 wires to remove entire harness. I retained original wiring for battery feed to stock fuse block, oil pressure gauge, water temp gauge, alternator wiring.
It seems cruise control is seperate part of the system. I noticed the speedo is a cable drive, works right off the TH400. The car has electric/vacuum cruise control. Where does the cruise get a speed signal? I traced the speedo cable all way to the back of the dash board and there is no device to make a speed signal I found. I was hoping I might be able to use this signal somehow for a VSS into computer.
Turbo is from a 2004 Dodge cummins 24v 5.9L. This particular turbo only has dyno time on it, so its practicaly new. A friend of a friend new someone at a chrysler R&D place and got the turbo. Thats the story anyways.
here's a few pictures...
Attached Thumbnails 5.3L in a 89' Caprice 9C1-100_2277-medium-.jpg   5.3L in a 89' Caprice 9C1-100_2278-medium-.jpg   5.3L in a 89' Caprice 9C1-100_2279-medium-.jpg
Old 01-19-2008, 03:48 PM
KC Henry's Avatar
Looks like its coming along nicely !
Old 01-20-2008, 11:42 PM
busta9876's Avatar
Any ideas where one could find the spark plug wire boot & terminal for the coil pack end of the wire? I'm going to have to remove mount the coil packs for this setup and need to make custom wires.....
KC Henry...what oil pan did you use in you'r swap? My truck pan hangs pretty low and i'd like to get a little more clearance...will the LS1 pan clear the crossmember? Got any pics?
Old 01-21-2008, 02:23 AM
KC Henry's Avatar
I used the stock 1998 Trans Am oil pan, and notched the cross member slightly. Unfortunately I do not have any pics, but will be trying to get the car ready for "World Of Wheels" car show here coming up and might be able to take some pics then.
Old 01-22-2008, 08:04 AM
The cruise probably gets a signal from a VSS right on the speedometer. This connects to a buffer box. If it's anything like the 80's monte carlos it's probably a 2 pulse VSS. That might not work with the 5.3 ecm.
Old 01-22-2008, 09:00 PM
busta9876's Avatar
got some pics of the turbo i'm using....
Attached Thumbnails 5.3L in a 89' Caprice 9C1-100_2284-large-.jpg   5.3L in a 89' Caprice 9C1-100_2285-large-.jpg   5.3L in a 89' Caprice 9C1-100_2286-large-.jpg   5.3L in a 89' Caprice 9C1-100_2287-large-.jpg
Old 01-27-2008, 10:40 PM
65SSZO6's Avatar
I don't want to but do you own LT1swap.com? and do wiring harness work? If so can you PM me some info:What harness would be the best to start with for a 2004 LQ4 long block,2004 ZO6 Camshaft and spring set,2000 Camaro intake w/stock injectors,drive by cable, 200R4 transmission with TCI lock up wiring harness. Vehicle is a 65 Chevelle SS.I would like to put the ECU under the dash and have minimal under hood wiring.What would it cost for you to modify said harness if I supply?if you supply?Thank you for consideration.
Quick Reply: 5.3L in a 89' Caprice 9C1
