swap help for ls1 in 97
Old 01-06-2008, 09:13 PM
scott5586's Avatar
Default swap help for ls1 in 97
i wreck my 01 ss and i bought a 97 v6 body. I already did everything swap everything over and the car runs. but the hood wont close because of the air lid. does anybody know what i can do to get the hood to close. i still have the stock 97 hood on there. would a ss hood clear the lid or ultra z hood. any help would be appreciated
Old 01-06-2008, 10:41 PM
SweeTbone's Avatar
I've seen one person do it. You can do a search and see if you can find it. I believe they had to trim the radiator shroud though. Most 93-97 LS1 swaps I've seen they use the stock LT1 style intake that goes down to the drivers side fender.
Old 01-07-2008, 11:52 AM
scott5586's Avatar
so i can just use the lt1 elbow. i thought the lt1 tb was oval will it fit the ls1 tb?
Old 01-07-2008, 08:32 PM
SweeTbone's Avatar
I believe you can use a GTO elbow from the TB to the MAF, the a regular LT1 style intake from the MAF to the filter. Or even use Fernco type tubing to custom make one.
Old 01-08-2008, 12:31 AM
SweeTbone's Avatar
https://ls1tech.com/forums/conversions-swaps/829707-post-up-some-pics-your-intake-piping.html
https://ls1tech.com/forums/conversions-swaps/111970-need-some-help-air-intake.html
https://ls1tech.com/forums/conversions-swaps/644175-intake-elbow.html
Just a quick search. Top thread here has some good pics of various intakes and elbows. I read in one of the threads that a LT1 elbow will fit a LS1 TB, it just needs to be stretched into place.
Old 01-09-2008, 05:24 PM
scott5586's Avatar
thanks for all the help, i didnt think about the gto elblow, my brother in law had a gto that he totalled but he took of his k&n intake and i was able to use that. does it matter where i place the sensor that is on the regular air lid?
Old 01-09-2008, 10:38 PM
SweeTbone's Avatar
If you are talking about the IAT sensor, I would say no, it don't matter. I've seen one guys swap on with a FAST 90 intake and he had that sensor in the EGR Port. Similiar to an LS6 intake it is blocked off, then just drill the proper size hole. I'm sure you could put it just about anywhere in the stream of air and you should be all right.
Old 01-10-2008, 10:51 AM
scott5586's Avatar
yea thats what i thought, i was just wanted to make sure. thanks for all your help. The car is up and running strong. last night i took down a 01 ss, and a 07 mustang gt.
Quick Reply: swap help for ls1 in 97
