carb intake
Old 01-17-2008, 05:17 PM
GraphicNature's Avatar
Default carb intake
which carb style intake should i go with on my motor with big cam and heads on a stock bottom end. im putting it in a mustang and what cam suggestions do yall have for a carb thanks for the input
Old 01-18-2008, 11:37 AM
bygblok's Avatar
I went with the Performer RPM. I also have a stock bottom end(other than ARP bolts) and I also plan to spray it. By using the Performer I limited my use of spray to a 150 shot because of the dual plane design. Thats about all it'll handle before you have separation issues between the nitrous and fuel. I also like the little bit of low end grunt it gives over a single plane. When I build a stroker motor I'll be going with more intake but thats going to be a while and I want this one to stay together at least to that point!!
