Question about an LS1 swapped LT1 car *dash question*
Old 01-29-2008, 11:38 PM
KriegerEhre's Avatar
Default Question about an LS1 swapped LT1 car *dash question*
So, If I buy the speartech wireing harness for the LT1 to LS1 swap - I can use my stock 95 camaro gauges right? - that's what the harness swap is for assuming yes?
Old 01-29-2008, 11:57 PM
sawzall wielding director
G-Body's Avatar
Yep, the speartech harness should be a direct plug in and you can use the LT1 cluster.
Old 01-30-2008, 12:01 AM
Alright sweet - this build doesn't seem so complicated no more or less than converting a small block car into a big block car back in the old days!
Old 01-30-2008, 09:08 AM
95GreenZ28's Avatar
You can still use your lt1 gauges if you do the wiring yourself as well
Old 01-30-2008, 10:13 PM
MeanGreenLT1's Avatar
Yup i bought mine from there and everything plugged right in. Best purchase of the whole coversion cause i hate wiring!
Quick Reply: Question about an LS1 swapped LT1 car *dash question*
