Getting motor/tranny tomorrow - Check list?
I want to make sure they include everything they said they would and everything I need. I'm trying to make a check list to make sure I get everything I need or should get.
So far, this is my list:
2002 4.8L Engine/4L60E tranny
ECM
Complete harness
Drive by wire throttle pedal/controller/harness
MAF sensor
Fuse/relay block
EFI Pump (going to give it to me, may or may not use it).
Anything else I should get while I'm there?
Thanks!
ECM
Complete harness
MAF sensor
Fuse/relay block
Thanks!
I'm putting it into a 79 Malibu. Engine is complete with accessories. I bought TransDapt engine mount adapter (similar to S&P). I plan on getting stock F-body exhaust manifolds. I will probably run the smog equipment, haven't decided yet. I'd like to keep it as simple as possible. I'm hoping the truck accessories and pan will fit, I'll just have to mock it up and see. At this point I'm just wanting to make sure I'm not forgetting something that I should get when buying the "drop-in" motor/trans.
You got that right, that's why I'm trying to get it all now. They seem to be pretty accomodating so far. I'm afraid they might want to charge for any "extras" if I go back.
sawzall wielding director
I saw the post on malibu racing. The tahoe fuel pump should work, there are 2 styles. One has a single inlet and will work, the other has dual inlets and I don`t know if it will fit. You will have to take the fuel pump out of that bucket/sender assembly. Both fuel pumps will probably have 2 outputs, on that goes to the 3/8" fuel line and a smaller 1/8" line that goes to the venturi system in the bucket. You can use a compression fitting on that line and then drill a 1/16" hole in a cap and put it on that line.
