Car starts for a few seconds and dies.
Old 02-21-2008, 06:37 PM
71chevellels1's Avatar
Default Car starts for a few seconds and dies.
Thanks for thoes who have got me this far. The car is a 71 chevelle with a turbo ls1. When i try to fire this baby up it runs for any where from 1 to 4 seconds. I dont know my fuel pressure because im waitinig for my gauge to get here. but my fpr has a setting from 20-70 psi so i have it turned almost all the way open at 70. I would guess its at about 50-60. All my sensors are pluged in except for 1 of my 02 sensors because it dosent reach, i will be getting a extension soon. ANyone have any ideas of what this could be? Thanks for all the help guys
Old 02-21-2008, 06:45 PM
vettehead's Avatar
I installed a LS1 in an older vette, and had the same problem. It would start and run for about 5-7 seconds.I finally had to have the ECM reprogramed for the second time. Some type of secerity had to be elemitated, so i was told. Afraid there is a lot about the ECM I don't understand.
Old 02-21-2008, 06:47 PM
who did the pcm the first time?
Old 02-21-2008, 06:59 PM
brownz's Avatar
does the pcm have the vats taken off of it? that would cause this problem
Old 02-21-2008, 07:11 PM
Ya im guessing so. Its a wait4me tune.
Old 02-21-2008, 07:16 PM
Also to clear things up. Sometimes when i turn the key it runs for anywhere from 2 seconds to 5. Its different everytime. Im guessing its fuel problem?
Old 02-21-2008, 07:20 PM
ls1nova71's Avatar
Sounds like a Vats issue, would contact Wait4me to make sure Vats was removed.
Old 02-21-2008, 09:12 PM
Slip-n-slide's Avatar
Im also going to go with the vats.....https://ls1tech.com/forums/conversions-swaps/567630-homemade-vats-bypass-box.html
Take a look at that link....
Old 02-21-2008, 10:16 PM
ACONLP's Avatar
sounds like vats to me
Old 02-21-2008, 11:34 PM
sawzall wielding director
G-Body's Avatar
Will it stay running if you give it some throttle? I know that sometimes if I have my battery disconnected long enough it will forget the idle and I will have to give it enough gas to keep it running and slowly back off over a couple minutes.
VATS does sound like a possibility though.
Old 02-21-2008, 11:54 PM
ls1_chevelle's Avatar
Let me take a wild guess. You do not have a MAF hooked up?
mine did the same thing until I plugged my MAF in.
Old 02-22-2008, 01:40 AM
JoePZ28's Avatar
Sounds like vats to me too.
Old 02-22-2008, 01:11 PM
No my maf is not plugged in.
Old 02-22-2008, 01:35 PM
Pete 1's Avatar
I had the same problem, turned out to be vats cutting off the injectors I had the ecu flashed by Wortec and she runs fine now.
Old 02-22-2008, 02:15 PM
If it is the maf sensor not being plugged in can i get a maf and just plug it in but not incoporate it into my system?
Old 02-22-2008, 02:19 PM
Well are you setup for speed density? What did your harness start out as? My harness was a truck harness and ran it with a maf for 2 years but went to Speed Density this year. Got rid of my MAF and added the syclone IAT sensor and harness. Then the ecu has to get programmed for the car to even run.
Old 02-22-2008, 05:17 PM
brownz's Avatar
this might be out their but maybe a major vacuum leak? just a thought!
Old 02-22-2008, 05:39 PM
I dont think its set up for SD. Stock 99 ls1 harness.
No vacuum leaks
Old 02-22-2008, 08:31 PM
LS1MCSS's Avatar
If it was originally programmed by Jess @ wait4me, then chances are real good that it is already setup for speed density.
Old 02-22-2008, 08:33 PM
ls1nova71's Avatar
If your not running s/d (and 99 stock harness, your not) you need to hook up the MAF, but it HAS to be incorporated in the air intake. Mine freaked out when I tried that! So the easiest thing to do to see if it would run was to duct tape the MAF to the throttle body, ghetto as hell but it worked.
Quick Reply: Car starts for a few seconds and dies.
