fuel pump and tank questions
running a stock ls1 in a 67 nova, and using the 67's stock tank. do i have to put a sump in it? or can i run it through the sending unit? were is everybody getting there pumps from?
There are a few ways to do this as you probably know after a little research.
You could sump the tank w/an external pump, or install an in-tank pump as mentioned earlier.
If you are asking if you can just suck fuel through the sending unit via an external pump, well... you could but you are running the risk of starving your motor of fuel when the tank gets low. The "fuel injection" pump demands allot more fuel than the "carb" pump that the tank/sending unit was built for in your 67 nova. There is no baffling inside the tank, so when the tank is low and your sloshing fuel around while driving you run the risk of starvation.
Or I guess you could just drive really slow and take it easy on the turns
If I build another car, I would either just go w/a rock valley converted tank or the tanks inc. set up because of the time involved. (time is money, at least at my age).
I converted my 69 tank with an in-tank pump, and baffling myself. The baffles run lengthwise and I have a spiral baffle that surrounds the pump. One of the benefits of the in-tank pump is the pump is being kept cooled by the fuel around it, hence, it "should" last longer (How many cars today are made with an external pump?)
Here are some pics of what I did.....
You can just see the spiral baffle inside the tank.
Lengthwise baffles (maybe overkill, but I plan on throwing this car around...alot!)
chrisp3,
did you build that plate (that the fuel pump/return is mounted to) or purchase it somewhere? I am looking to do the exact same thing very soon. Also, how is it attached to the tank? Is the bottom piece threaded? I cant tell from the picture. Thanks
chrisp3 Could you better explain your "spiral baffle" or better yet post a pic.
I'm doing a 68 Cutlass LS1/A4 conversoin. I too am considering the Tanks inc. setup but have concerns over lack of sump.
Eric
Eric
I am wondering the same thing. My Biscayne ( Impala ) Wagon tank is mounted inside the fender and they are not reproduced. I am wondering what to do, and cost as well. trying to figure up the budget needed for my vehicle.
Any advice would be great. I cant go to a trunk space mounted tank b/c of a third row seat.
I'm no expert but I highly dought fuel sloshing is going to be that big of deal in a 60's model mucle car. I have a 1993 chevy truck with efi. It cuts out when corning when the tank is down to a gallon or so. It just tells me hey you better put some gas in it. Odds are if your like me you are not going to be doing high speed g turns in your A body. If your budget allows you to do the road hugging all out suspenion and your going to be turning and burning then you would diffently need a sumped and baffled tank. I am building a fast straight line cruiser so I took the cheap route and mounted an external welbro with vet regulator. Let your wallet decide.
In my case I was able to buy a new sending unit with 3/8 feed and a return line in it already. I spoke to this guy Danny
http://www.tristarrradiator.com/New%...g%20Units.html
He said you can send him your existing unit and he can put a return line in it for you.
Good luck
Good luck
