ls1 Stand Alone Wiring Harness Diagram
HI guys Im taking the plunge as well into this Ls1 stuff and currently stuck a 75,000k (canadian truck) 4.8 out of a 2006 Express van got it for $300 complete with harness/PCM but the harness has been cut in a few places (all plugs for sensors there) by the hack job wrecking yard I bought it from. I want to make it a stand alone with as little as possible and I plan to use the o2's (only 2) I dont know if I need the purge solenoid that is almost touch my cowl hood at the fron of the intake... If anyone has any advice on the PCM tune I should get for this Im open to any advice or tips... My car has a Ford 9" 4:10 strange spooler/axles, roll cage line lock, th400 2500 stall I dont even know a decent place to send this PCm to as Ive yet to here of anyone in Canada doing it.. OH I need to find a car oil pan if anyone has one because the truck pan just about touching my cradle and my sterring is hitting the pan on the passenger side. If anyone knows a wreckers that has a car oil pan that would be awesome ttyl Great site!
Ls harness info
Any info you could possibly need is at lt1swap.c0m. I had no idea what I was doing and swapped an lq4/4l60e into an 82 silverado. There is a pin out for all the different harnesses there that is pretty straight forward, you only need to hook up a positive, a ground, and an ignition. Plus the guy who runs the site can flash your PCM to remove vats, change your trans, and remove torque management for $75 including shipping, that way you can drive it to a tuner if you have other mods. You can either figure it out or pay $700+ for a standalone harness, I'm cheap so I used the inter webs for guidance.
Hi guys, can I have a copy of the diagram too? Any help be appreciated this is my e mail marcos8993@msn.com
Thank you.
Thank you.
You can ditch the evaporator solenoid , I think most do anyway, plus makes a nice home for a air sensor it you wanna ditch the maf and go with a speed density tune
#34
Ls1 wire harness
#35
Would you please email me what I need to make my 2001 camaro wiring harness a stand alone system.
Thanks
Mike
Madowling76@gmail.com
Thanks
Mike
Here's the site with all your pinout info.
http://lt1swap.com/2001_PCM_CONN_PINOUT.htm
#38
2002 LS1 wiring conversion
Hi I have been reading up on the wiring and have all the pin out details but does someone have a simple detail of which wires to remove to get the engine running. As i am not sure which wires are required and which are optional. I am putting into a 1952 Chev Loadmaster converted to pick up.
