Oil pan alignment
Oil pan alignment
K, so I got the correct tool from ebay for cheap, how do you use this thing? I don't have a manual for any ls1 car/truck but do have the alldata which does not use this tool at all in there procedures. I can figure it out I guess but some of you have used this right? What is the torque on the oil pan bolts while I'm at it?
Thanks
Thanks
This might help, go onto www.hotrodlane.cc and click on tech for ls1 there is alot of info, hope this helps
Check this article out:
http://www.gmhightechperformance.com...alignment.html
Scroll through and look at the pictures with discriptions.
I used a level to align the rear cover and front cover with the block. Place the level on the oil pan rail and use a feeler gauge to check the front and rear cover. No more than .002" gap between either side
and what chuckyt1 says to align the oil pan with the rear of the block
If you have an automatic you can use a level to square the back of the block and the rear of the pan before you tighten the pan bolts
I hope that explains it. Do not put any oil on the rear seal. I did that on the first one I built and it started leaking after it was all done. That was a bummer.
No, just let the seal center the cover. Then I used the feeler gauge to check the bottom of the cover with the pan rail and the level ( You have the tool for that). Once you get it square you just tighten it up the cover. Then I put the bell housing on the block (if you have a manual tranny). Put all the bolts in the pan (loose). Tighten the bolts to the the bell housing and draw it to the block, then draw the pan up to the bell housing, then tighten the pan bolts.
