LSx engine swap in 1999 Sonoma Tach ?
Old 04-02-2008, 10:13 PM
oct03gto's Avatar
Question LSx engine swap in 1999 Sonoma Tach ?
About to start up a 2001 5.3l 4L60E swap into my 99' Sonoma that came with a 4.3l and 4L60E. I can take care of all the mechanical parts. And the wiring to get the engine running. But I want to keep the stock cluster with tach.
Is there a way to calibrate the stoc factory 4.3 v-6 tach to work with the LS engine electronics? I know the older s-10's wan't hard. Just a diode swapout.
I figured at 200k miles, the stock 4.3 needs to find a new home.
I am sure I will have more ?'s. But I'll continue the search first.
Old 04-03-2008, 01:35 AM
sawzall wielding director
G-Body's Avatar
You can just reprogram the LSx tach output in the computer to make the tach work. Either HPTuners or EFILive7 can do it.
Old 04-03-2008, 05:39 AM
Jones'n's Avatar
Or, don't do anything at all and it will work just fine... believe it or not.
Old 04-03-2008, 08:42 AM
01WS6/tamu's Avatar
The tach signal from the ls pcm is the same as the v6 since it is a pcm generated signal.
Old 04-03-2008, 09:39 AM
andrew69_04's Avatar
yep. you might consider buying a 2.2 cluster so you can have the 7k rpm tach. the 4.3 was only 6k. both tachs work great with the ls platform. im running the 2.2 with my setup.
Old 04-03-2008, 05:58 PM
oct03gto's Avatar
Thakns for the info fellas. I do plan on adding a small cam and custom LT's. So a tune is going to be needed. As well as for the differance in tire sizes.
The cluster swap is also a good idea. As I will want the extra RPM's and an engine matched milage. Being that this truck has 198k on it. A bit worn. LOL
Quick Reply: LSx engine swap in 1999 Sonoma Tach ?
