Flexplate
Old 04-09-2008, 11:35 AM
JBT
JBT's Avatar
Default Flexplate
Do I have the 4L80e or the 4L65e flexplate on the LQ4?
I'm asking because I tried to fit a th400 and it was very tight between the converter and the flexplate. There is a spacer between the crank and the flexplate.
Old 04-09-2008, 12:17 PM
ryanvv355's Avatar
LQ4 will have the 80. LQ9 will have a 65
Old 04-10-2008, 10:03 AM
LS1TECH Sponsor
Carshopinc.com's Avatar
Thats a 80 flexplate, it's got 6 converter bolt holes and is not offset.
Old 04-10-2008, 03:44 PM
forcd ind's Avatar
if your converter is in all the way, a 400 should fit ok, with the .400 spacer and flat flywheel, which it looks like you have-i just installed one in mine
i had to pull the starter motor to install the converter bolts
Old 04-10-2008, 04:44 PM
JBT
JBT's Avatar
I tried again today and now it fit perfect. I dont know what went wrong last time i tried.
It looks tight to install the converter bolts.
My th400 came with a thick aluminum flexplate cover, and that won't fit when the trans i mounted to the lq4. Is it common that the thick aluminum convers wont fit when you have a LS engine?
Quick Reply: Flexplate
