why are all bolt in crossmembers crap?
maybe i just had some bad luck but my wife actually let spend some money so i bought a prefabbed crossmember and it fit like ***.
so i called the company and they asked me for the measurments on it, and agreed it was bad and must have been made on a friday or something, so they sent another and told me to pitch that one in the trash.
i thought cool at least they stand behind their product. so i get the new one and its almost as bad as the old one.
i have NEVER had a stock crossmember from one car to another not fit. so why is it so frickin hard to make an aftermarket one fit. i still had to mangle the new one.
the mount was way off
i had to mangle it to get it to fit
you can see how far off the mount is and the mount had ajustment and its all the way left
and there is barely a diff between the two.
You are going to find a difference based on which mounting plates you used, which mounts you used, and which pedastals. I can easily envision that much error just in plate diferences...
I am working thru a similar problem with my 55 Chevy convertible, with an LQ4. I purchased the engine mount kit and cross member kit from the same supplier. The cross member misses by about two inches ( too far forward)). They sent me several different styles to try and no luck. Not an easy fix since the convertibles have that big "X" frame. Going to have to cut one of these aftermarket beauties and fit it to the "X". I will probably wait until I get the body off so I have more room to work.
yeah but the plates dont have anything to do with the frame. this p.o.s. didnt fit the frame.
this is just a plain jane 68 camaro. if it was some crazy custom job i wouldnt gripe. now i have to figure out what way to kill the extra crossmember.
should i set it on fire or blow it up, or maybe make a piece of art out of it!!!
**** man just make your own. 3 pieces of 1/4 inch angle iron, a chop saw, a drill and a welder are all you need. its super easy to build the transmission mount.
Say it anyway. I don't think any companies that pay to be here would mind us avoiding their competition. Not like this is a good review so people will run out to buy their product.
