reworkin my harness questions???
Old 04-21-2008, 02:49 PM
jkwalkercchs's Avatar
Default reworkin my harness questions???
ok i have an 03 chevy avalanche that i have takin the dash and steering wheel out off and plan on doing a custom sheetmetal dash with a removable steering wheel and toggle switchs for my ignition and such with a push button start and of coarse aftermarket gauges
anyone have any tips on how to do this i am very good with electrical and aint afraid to hack the harness up
Old 04-21-2008, 07:53 PM
Or Should I Just Send It To Speartech???
Old 04-21-2008, 08:31 PM
IHeartTurbo's Avatar
If you are "very good with electrical" why are you asking such a vague question? And why would you send it to speartech if you are so good?
Old 04-21-2008, 09:51 PM
because i dont know where to even begin on where to hook the gauges up and such and i cant find a good diagram of the wiring harness
Old 04-22-2008, 08:08 AM
Then you haven't looked hard enough.
Old 04-22-2008, 05:20 PM
I have one but its for a chevy express van just need some info on which pcm wires to tap into to make my gauges work
Old 04-22-2008, 05:25 PM
RE AND CHERYL's Avatar
For a project like that I would get a Helms manual set for your vehicle.
Re'
Old 04-22-2008, 07:12 PM
where could i get one of these
o wait the ones they sale at advanced??
Old 04-22-2008, 08:11 PM
Project GatTagO's Avatar
Received 1,389 Likes on 878 Posts
I have nothing to contribute except to say that your avatar is HOT!!!
Andrew
Old 04-22-2008, 08:30 PM
Andrew
lol but yea i got a diagram now that i can use yay
anyone wanna chime in on which wires to tap
Old 04-22-2008, 10:46 PM
Rodder's Avatar
you need to run new sending units for oil and temp, you can't just tap the old senders. For tach and speedo, there are outputs on the PCM--no idea which pins on a truck PCM, go look at the wiring diagram for the donor vehicle.
Old 04-22-2008, 10:48 PM
lol this is the donar vehicle lol
thanks though so im guessing oil and temp is easy though
tach which wire i have the diagram what would its name be??
Old 04-22-2008, 11:05 PM
Rodder's Avatar
Take a look at C2-10 for "RPM OUT" and C2-50 for "VSS OUT". That's what I found in 5 minutes of looking at an '01 Silverado 5.3 diagram--dunno if your '03 Av is the same.
Old 04-22-2008, 11:21 PM
there different i have a wire thats number 10 pin on the ecm and is white says engine speed signal im guessin thats it
Old 04-23-2008, 07:13 PM
ok guess figured out how to crank it yay any ideal what size fuse i need on the relay??
Old 04-24-2008, 02:44 PM
MikeMoss's Avatar
there are some pretty good wiring tutorials for rx7 ls1 swaps that might help you. I dont have them on this computer if you want links i can post them when i get home.
http://www.grannysspeedshop.com/ Has some wiring stuff in the manual section. It isnt specific but might help.
Old 04-24-2008, 10:04 PM
kool if u would post up that would be nice but i think im gettin it figured out
Quick Reply: reworkin my harness questions???
