What would cause the vette filter/reg. to blow?
Old 04-22-2008, 07:09 PM
JAY ROD's Avatar
Default What would cause the vette filter/reg. to blow?
I was having issues with my conversion running because My fuel rail was only getting 35 psi and the return line was shooting all the fuel back to the tank.I cut apart the filter and found a blown seal at the return port.Was this bad luck or is my walbro 255 100psi pump to strong for this style of filter?.(aftermarket)
Thanks for any input.
Old 04-22-2008, 07:12 PM
hpmotorsports's Avatar
Could have been just a defect , you didn't hook it up wrong did you?
Old 04-22-2008, 08:35 PM
JAY ROD's Avatar
Thanks for the response,the filter was hooked up right.5/16 to return,3/8 male inlet,3/8 female outlet.
Old 04-22-2008, 09:28 PM
RE AND CHERYL's Avatar
My Vette filter has worked fine with my Racetronix 255lph pump for several thousand miles with no problems. I'd try to get wouever you bought it from to replace it as defective.
Re'
Old 04-22-2008, 09:41 PM
jkwalkercchs's Avatar
um where is the regulator at on the ls2 rails??
Old 04-22-2008, 10:50 PM
Rodder's Avatar
Was this a real Delco filter/regulator or a Wix?
Old 04-23-2008, 07:42 PM
JAY ROD's Avatar
I am unsure of the brand,it was not G.M
Quick Reply: What would cause the vette filter/reg. to blow?
