LQ4 598, 595 do I need valve reliefs
Old 04-23-2008, 10:01 PM
SUPERWAKE502's Avatar
Default LQ4 598, 595 do I need valve reliefs
I have a stock block and head 06 6.0L. I have a 595, 598 lift and the motor seems to turn over fine. Super chevy said they had to cut valve reliefs in the pistons with only 570 lift. DO I HAVE A PROBLEM HERE. I know someone has got to have a big cam in one of these. I had no luck in another post. It has not started yet, Lee
Old 04-23-2008, 10:08 PM
mred's Avatar
sorry, but only you can be for sure, i have been told you are at the limit.
i would say .590 is the limit
Old 04-23-2008, 10:13 PM
burgers's Avatar
We are running a 6.0 with L92's, .060 gm mls gaskets, Tsp 233/239 112 cam with lift at .598 and .603 and have no problems and no notching. It all depends when the valves are opening, closing and for how long there open.
Old 04-23-2008, 10:50 PM
Well its a 232 and 234 duration on a LSA of 112
Old 04-24-2008, 09:38 PM
TJ
TJ's Avatar
602 lift here with milled heads, im good. it all depends on the design of the cam.
i would get with whoever ground the cam. if in question, you need to pull a head and clay it.
Old 04-24-2008, 10:02 PM
Thanks guys, ya'll have given me what I needed!
