Blocking off the nipples anyone
Id like to block off the heater nipples on my water pump so I have more clearance for my crossover on my turbo setup. I clamped some rubber caps on but Im afraid they wont hold up well with the heat. Plus I could really use the 1 1/2" clearance. I thought about removing the tubes and drilling and tapping the holes to 3/4 npt and using screw in plugs. Anyone done this? Suggestions? Pics?
I dont understand why overheating would occur for some not others so I looked at some t-stats I had laying around and I think I figured out why. The older style 1 piece thermostat and water neck have a flat disc on the heater bypass portion of the thermostat and the newer design has three holes on that disc allowing coolant to bypass it. I just cant see GM allowing their engines to overheat from a plugged up heater core. What do you guys think?
sawzall wielding director
On my install I used the valve from the El Camino so it does shut off the coolant flow if I don`t have the heat on. A few people have said this causes problems, but I haven`t had any problems in the 25k+ miles that I have put on so far. IIRC John B was/is? running the same heater setup as me.
A few people have recommended a valve from a astro van (I forget what year) because it has a built in bypass for when you turn the heater off.
