Altenator? - LS1TECH
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
Altenator?
Thread Tools Search this Thread
Old 05-07-2008, 02:04 PM   #1
97'-lt1's Avatar
Default Altenator?
I know this has been done several times..and I did search but couldn't really find any information towards a carb setup..I'm building a 6.0 LQ4 based motor and will be using only the crank water pump and alternator. My question being how to hook up the factory truck alternator without having a harness. Do I have to plug anything into the plug on the alternator or will it work fine without..?
97'-lt1 is offline   Reply With Quote
Old 05-07-2008, 04:49 PM   #2
Get the pigtail connector from ebay. They are like $10. The you will need to solder a resister between one of the wires. This simulates the computer telling it ot charge. Then you wire the other wire to your battery. There is a big thread about this on here, i had it bookmarked then my broswer decided to uninstall itself so i lost all my little helpful tidbits.
Shawn MacAnanny is offline   Reply With Quote
Old 05-07-2008, 08:45 PM   #3
LS1MCSS's Avatar
You run 12 volts, switched, through a 470 ohm resistor to pin B on the alternator.
LS1MCSS is offline   Reply With Quote
Old 05-07-2008, 10:55 PM   #4
sawzall wielding director
G-Body's Avatar
http://www.ls1tech.com/forums/showth...ght=alternator
If its a 2001 or newer truck alt it needs 2 wires.
Switched 12V to terminal C, and switched 12v to 470 ohm resistor to terminal B.
G-Body is offline   Reply With Quote
Old 05-08-2008, 07:45 AM   #5
97'-lt1's Avatar
Thanks guys I talked to a local alternator shop yesterday and they said that I can have it converted to a one wire set up for about $50. So I think I might be going that route..
Old 05-08-2008, 11:17 AM   #6
Project GatTagO's Avatar
Quote:
Correct me if I am wrong, but the one wire alternators need to be spun past a certain RPM so that it can be "excited" to start charging. If you wire in the resistor you can just start the car and let it idle and the alternator will automatically start charging. Save your 50 bucks and wire in the resistor.
Andrew
Project GatTagO is offline   Reply With Quote
Old 05-08-2008, 03:53 PM   #7
97'-lt1's Avatar
I'm not aware of that..if this is true what at RPM does it start charging..I've never heard of this..
Old 05-08-2008, 03:57 PM   #8
yes, thats why 1 wire alt + underdrive pulleys sometimes = dead battery.
JayofDestruction is offline   Reply With Quote
Old 05-08-2008, 04:08 PM   #9
97'-lt1's Avatar
Hmm..Anyone know the rpm..? It mainly going to be a track car..
Old 05-08-2008, 04:46 PM   #10
It is usually 2000-2500 rpm. For a track only car I would not worry about it. Once the alternator is "excited" it will keep charging even at idle.
Andrew
Old 05-08-2008, 04:49 PM   #11
97'-lt1's Avatar
Thats what I was figuring..
Tags
97, alternator, hook, lt1, single, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
