Lq4 And T56 In A Fox Body Swap
#42
This radiator is a universal aluminum we installed in this car when it was still a 5.0L. It was only a couple of months old and fit great, so we decided to try and reuse it. I will try to find the part number and manufacturer and post it tomorrow.
#45
Just use the pedal assembly from the gen fbody your trans is from. If lt t56 use pedals from 93-97 f-body otherwise use 98+ pedals for 98+ trans. Just so the clutch master is at the proper spot. But you can really use either or if your drilling your own hole in the firewall for the master.
#46
Here are some pictures of what had to be done to the firewall and pedals.
Stock Pedals
Modified Pedals
The clutch master cylinder attaches to the inside of the bottom stud on the lever in the above picture. The lever assembly was "finish welded" after about a dozen mock-ups and test runs, but I don't have a picture of it.
#48
well... i do believe i love you.
i have been looking for a nice visualization on how to setup the hydraulic master for a while now.
nice build by the way, just wanted to say thanks you for sharing.
#50
AJE/kooks/steering shaft
94Firehawk161, Did you run into any issues at all with steering shaft clearance even with running the kooks headers which are designed for the swap?
#51
Good job on the build and all the writeups. Im sure it helps a lot of people including myself. Did u put any kind of cam in it or is it stock? Have you taken it to the track at all?
