LS1 into 84 vette need info-wiring harness,ect
Old 06-05-2008, 10:41 PM
Casey84vette's Avatar
Default LS1 into 84 vette need info-wiring harness,ect
I'm putting a LS1 motor in my 84 vette. The current motor is a crossfire injection and with the new motor I will need all new wiring harness. My biggest concern is to keep the digital dash and other electrical gages working. Has any one done this?
Old 06-05-2008, 11:21 PM
sawzall wielding director
G-Body's Avatar
I don`t know if anyone has done that yet, but it should be doable. Just run the sending units (oil,water, etc) off the old motor (use metric to american adapters to thead them in) and then change the tach output in the LSx computer. If the vette has an electronic speedo it should be pretty painless to do. If it has a mechanical speedo it will require a bit more effort.
Old 06-05-2008, 11:58 PM
Rodder's Avatar
Just more money (a CableX box), but not much more effort.
Old 06-06-2008, 12:45 AM
G-Body's Avatar
Originally Posted by Rodder
Just more money
If that isn`t the truth. As we say in my family "Don`t worry, ain`t nothing money won`t fix"usually stated after someone breaks something
You can also go the cheap way like I did and put the guts of an electric speedo behind your factory speedo face.
Old 06-06-2008, 05:29 AM
Jones'n's Avatar
Corvette Enthusiast magazine did a whole write-up on installing an LS2 in an 84 or 85 Vette a few months ago. Since it is very much the same except for the Throttle Body, you might see if you can get one of those issues.
Old 06-07-2008, 02:04 PM
radrambler's Avatar
Default vette info
hi
mi friend chris did the swap you saw in the magazine...go to his personal website.www.mcspeed.com. you can contact him and get info..he did ls2 in an 85 .. hope that helps
radrambler
Old 06-08-2008, 12:26 PM
subtlez28's Avatar
Good luck w the swap. Do a nice write up and maybe I can bully my dad into swapping in an LS into his 84!
Quick Reply: LS1 into 84 vette need info-wiring harness,ect
