I finally got my engine, now I got some questions...
Hee there,
I finally got my '06 7k LS2 Corvette engine with 4L60e.
now I got some questions:
- The belhousing has a small crack on the underside, is this disturbing?
http://kandycamaro.com/temporary/belhousing_crack.jpg
- One of the o2 sensors looks busted, does this matter? or how to test it?
http://kandycamaro.com/temporary/O2sensor_busted.jpg
- I am missing 3 rubber cones underneed the engine covers to support it I guess, where to get those?
Or do they come with the engine covers when I order two new ones, these are busted a little.
http://kandycamaro.com/temporary/valvocoverpin1.jpg
http://kandycamaro.com/temporary/valvocoverpin2.jpg
I probably have some more question comming, thanks guys!
Peter
Peter
You could take the bell housing to someone who can weld alum... I should be ok... as I know someone who does it for transmission shops.
Just get a new O2.
Get the rubber cap at the local dealer.
I take it that this was a pull out from a cashed Vett. Better check everything over for more cracks.
Just get a new O2.
the belhousing is not from a vette and I checked everything twice, no big worries besides the cracked belhousing.
I am from the netherlands, so going to a tranny shop isn't thateasy and affordable, and going to the dealer isn't an option to...
Can I use one of the rear O2 sensors instead of this one?
any more tips are welcome
Thanks
Peter
Thanks
Peter
I need some more upinions on the crack in the bellhousing...
do I have to worry? do I need to do something about it or leave it this way? or should I replace? what is involved in bolting it off?
Thanks
Peter
Thanks
Peter
what do you mean, a leak? it is right next to a hughe open hole...
But all you guys say let's have it welded...
So I have to take it off and have it welded, dammm
thanks thought
Peter
thanks thought
Peter
