LSx Coolant Temperature and Oil Pressure Sender Adapters
Old 06-14-2008, 10:52 PM
brando1985's Avatar
Thumbs up LSx Coolant Temperature and Oil Pressure Sender Adapters
I've had a heck of a time finding coolant and oil pressure adapter fittings so I could run after market gauges. Just letting everyone know that Speedway Motors stocks both adapters.....They're not those cheap Equuis fittings either. Hopefully this will save someone a headache down the road....
http://www.speedwaymotors.com/LS1-Wa...pter,8195.html
http://www.speedwaymotors.com/LS-Ser...DisplayId=8195
Old 06-15-2008, 06:39 AM
DCx
DCx's Avatar
autometer.... (caugh caugh)
http://www.autometer.com/cat_accesso...st.aspx?pid=11
Old 06-15-2008, 09:13 AM
Shawn MacAnanny's Avatar
Collant adapter is Autometer Part number 2277. I had to drill out the inside of the adapter to fit their coolant temp prob which i thought was really dumb. It adapts M12x1.5 to 1/8" NPT.
Old 06-15-2008, 09:43 AM
SatisTraction's Avatar
i just tapped the passenger side heat to the NPT thread. took 5 minutes and was WAY easy.
used autometer for the oil pressure.
Old 06-15-2008, 10:32 AM
ponti-yak's Avatar
What size did you tap it out to? I have to go to 1/2 in NPT to accomodate my temp sender and I'm nervous about hogging the hole out that much.
Old 06-15-2008, 04:34 PM
DCx
DCx's Avatar
my shallow depth autometer 1/8 npt temp sensor fit fine in the m12 adapter.
Old 06-16-2008, 07:46 PM
Slow 346's Avatar
Autometer does sell a stubby temp sensor that works with their fitting FWIW.
Old 06-16-2008, 07:54 PM
Well you see i bought the gauge first from autozone and then bought the adapter and then just drilled out the adapter haha. I didnt know they made a shallow depth sensor though. Good info. While on the topic of gauge anyone know what OHM fuel gauge i will need for a 68 firebird? I see like 3 different options for Ohm roatings for fuel gauges from Autometer and i cant remember what mine is.
Old 06-17-2008, 12:06 AM
DCx
DCx's Avatar
sure thing....
http://www.autometer.com/cat_accesso...il.aspx?vid=33
i use this sender with my phantom gauges. works perfect.
Old 06-17-2008, 12:07 AM
DCx
DCx's Avatar
GM fuel sender is 90 ohm right?
Old 06-17-2008, 05:10 AM
LS1MCSS's Avatar
0-90 ohm
Old 06-17-2008, 05:18 AM
Thanks guys!
Old 06-19-2008, 10:44 AM
LS1TECH Sponsor
Carshopinc.com's Avatar
We have them in stock:
http://autometer.carshopinc.com/prod..._id/70398/2278
http://autometer.carshopinc.com/prod..._id/70397/2277
Old 07-25-2009, 07:58 AM
randall 32's Avatar
according to your web page the part 2278 should be 2268 , the other two are 2277, & 2259. but $12.57 to ship 3 items that fit in the palm of your hand is ridiculous
Old 01-29-2012, 03:46 PM
Squeezer's Avatar
Glad to have found this information today, Thank You!
Old 01-29-2012, 05:46 PM
Howerton's Avatar
I was looking for this info Thanks
Old 02-01-2012, 02:01 PM
Jeff Smith's Avatar
subscribed
Old 02-01-2012, 04:12 PM
bmf5150's Avatar
Street and performance has that stuff to
Quick Reply: LSx Coolant Temperature and Oil Pressure Sender Adapters
