98 car with 00 harness/pcm...HELP!
Ok Guys,
I can't find the link again, someone sent it to me before.
I am so close to completeing my V6 to LS1 swap. I'm using a 98 V6 a4 car w/ a 00 LS1, and PCM
NOW,
I'm the fuel tank, ENGINE harness, and PCM along w/ gauge cluster from a 2000 car.
NOW>..what will need to be re-pinned to connect the engine harness to the rest of the car?
Has anyone done this, or do you have a diagram of each?
Joe
ALSo, what will I need to do about the fuel tank sending unit wiring? or is it a direct swap?
BTW, I am removing EVAP
NOW,
Joe
Bump.
I guess 90% of the members on here really don't know anything, other than posting to threads that have been asked 100 times.
And Yes, I have searched..numerous times with no results
At the top of this section there is an FAQ.
Your Pinout information can be found there.
https://ls1tech.com/forums/conversions-swaps/312119-ls1-swap-faqs.html
Thats the pin-outs fopr the PCM connectors.
I don't need to re-pin that.
I need to re-pin the 3 plugs on the r/s fender, and the 3 that go in to the firewall.
Since I am using a 00 engine hanress, and will connect it to the underhood harness,etc
