Problem installing Tremec TKO 600 behind LS motor, mech linkage & clutch fork problem
Im doing my first Tremec TKO 600 behind a LS motor....
Ive got the adapter pilot bearing in the back of the crank, repro-"621" muncie bellhousing, tremec tko 600...., factory LS1 clutch/flywheel
It all bolts together with no problem THEN
I got a factory mechanical linkage kit that i was told would work for this:
I bolted it all up the clutch fork/pivot ball/throwout bearing etc and the clutch fork and it doesnt align in the center at all and the throwout bearing sits about 1" away from the pressure plate when its at the correct angle for where it should sit.
I attached pictures to give an idea.
Does anyone know where to get the correct clutch fork/throwout for using factory ls1 clutch/flywheel with this setup?
Looks as if you need a different fork. I almost did this in my Chevelle instead of the hydraulic. What brand of bellhousing and fork?
Also just for my reference was there an allignment dowel for the flywheel on the rear crankshaft flange? Or did you just line up the hole on the flywheel with the hole on the crank shaft?
I have this setup in my car. I used a factory 2nd gen clutch fork. It lines up fine. That fork just doesn't look right to me. But the other problem is that there is .4" of extra space as in the flywheel face is .4" further in on the ls1. So there are few ways to get around this. Apparently mcleod now has a flywheel which is offset the .4". I used a thicker throwout bearing. You also use an adjustable ball stud I guess. If I was to do it again I would use the different flywheel but I did not know about it at the time. With the thicker bearing all my angles are good and bearing is centered.
I looked at the picture again. The T/O bearing is supposed to rest on the two fingers of the fork, not pushed all the way into the fork. That should line you up. Do that and take a picture.
There is no alignment dowel, but it is lined up with hole in the crank. Flywheel is on correctly.
I agree that i believed it needed a different fork, after Fortes (tremec parts place) believed they sent me the wrong fork and sent me out another one, it appears its the exact same fork....
So if i need to source one myself then should i just get a factory muncie clutch fork?
Does anyone know part # or where to order thicker throw out bearing OR a .4" longer adjustable pivot ball?
Also don't forget the pilot bushing. (in my first manual swap I never knew you needed one.)
Ben-
summit has an adjustable throwout bearing. not sure on pn. they also have the adjustable ball stud. Local supplier might carry them also. They are mcleod parts. My mechanic buddy just happened to have one so I never had to order.
I used an adjustable ball stud on my Corvette. It's adjusted as far out as I dare and it is just barely enough. I'm running an aluminum LS7 flywheel and LS7 clutch with the factory Muncie 4 speed. I have a Lakewood explosion proof bellhousing made for conversions. The depth is the same as a regular one, it's not .400 shallower
I used an old style 'long' throwout bearing and an adjustable ball stud to get my Muncie setup correctly. Your clutch fork is fine. The bearing rides out on the fingers.
could someone pm the parts list needed to put a tko600 behind the ls motor
i dont wanna mess with hydraulics in my conversion and the tko i have came out of a mustang just like mine would be a really easy swap as long as someone makes the bellhouston fly wheel etc parts
if anyone has the info pm me pleaes id highly appreciate it
you have not got bearing in right it dose line up mate you have pushed bearing in to far but i would go internal hydraulic puts even pressure on pressure plate and you can shim bearing in or out
I agree with 70-cloned, the TO Bearing should be setting on the fingers in the middle of the Bearning, not seated all the way against the fork as you have it.
Try removing the Bellhousing, leave the fork and TO Bearing in place in the bell housng, then mock up by mounting the Trans to the bell housing.. and you will see how well the fork and Throw out bearing lines up on the Input shaft and Bearing Retainer. Also get an Adjustable ball stud and measure and adjust the stud.
No fork Problem
Get your clutch alignment tool put it through the throw out bearing. The bearing should rest on the fingers near center of bearing. Not how pic show its way too deep in fork.
