LS1 injector/rail clips?
Old 07-07-2008, 12:42 PM
garys 68's Avatar
Default LS1 injector/rail clips?
I had to swap out my LQ9 truck intake/injector/fuel rail for an LS1/intake/injector/fuel rail.
I've got the full LS1 setup, but there's no clips between the injectors and fuel rail. Are there supposed to be clips on the LS1 (2002)? Are they the same as the truck intake injector clips?
Anyone got a part number for them?
Gary
Old 07-07-2008, 12:53 PM
bczee's Avatar
There is no clip on the Fuel rail itself to secure the injector. The electrical connector (Pigtail) for the Injectors have a clip integrated on to the connector that would secure it to the injector. The injectors are just press fitted into both the Intake and fuel rail with only O-Ring. The Fuel rail is then bolted down to the intake to keep all secure.
If there is no square shape clip in the injector connector, either your wiring harness / connector are missing the clips or someone has removed them. I am not sure these are serviceable parts and may not be replaced, check with your local parts shop (catalog) or at the dealer.
Old 07-07-2008, 12:58 PM
garys 68's Avatar
Thanks, I still have to order injector connector/pigtails and swap them out.
BTW, I also had the LQ9 computer reprogrammed for the LS1 injectors too.
Sabre002's Avatar
yes there are clips that hold the injector to the rail I have taken them off many time.
here is a pic of them
Old 07-07-2008, 03:31 PM
ls1nova71's Avatar
All of mine have had the clips. They seem to be interchangeable though. I just tried it and the truck clip snapped on the Ls1 fuel rail, no problem that I saw. The clip on the right is a 2001 Ls1, the clip on the left is a 2002 6.0.
Attached Thumbnails LS1 injector/rail clips?-photo0502.jpg   LS1 injector/rail clips?-photo0503.jpg
Quick Reply: LS1 injector/rail clips?
