ls1 in a 93+ rx7?
Old 07-10-2008, 09:37 PM
Disturbed Bird's Avatar
Default ls1 in a 93+ rx7?
how much will cost and are there any write ups?
Old 07-10-2008, 09:46 PM
93formto98T/A's Avatar
Been done too many times to count. I'm getting started on a 93rx7/LS7 swap as we speak. Try v8rx7forum.com
Old 07-10-2008, 09:51 PM
cdk4219's Avatar
Wow, where have you been? I usually frown upon the members that quickly bring up the search button, but in this case you might have to do a tiny bit of work. This swap has been done 2 billion times and there are many write ups on it, and lots here as well.
Old 07-10-2008, 09:52 PM
i did. couldnt find anything on that site as a write up. can you post a link
Old 07-10-2008, 10:31 PM
Skele4door's Avatar
There aren't really any complete writeups since everyone builds them a bit differently. Spend a few evenings reading threads over there and then start askign questions. If you don't use the search function you'll find that people quickly stop bothering to answer your questions since we've had a bunch of tools join and expect to have everything spoon-fed to them. Good luck.
Old 07-10-2008, 10:50 PM
well since iv been here since 2006 and have over 1,200 post i know how to use this forum. i tried and i came up with nothing. everyone needs to lighten a grip in this section. im just trying to find a little info on the swap.
Old 07-10-2008, 11:16 PM
Honestly I don't know if a true "rx7 swap writeup" exists. I'm sure most of the build is straightforward then when problems arise, that's when they start posting stuff up. Nearly all the swap parts can be bought off the shelf of a few different vendors...(nonsponsors).
Old 07-11-2008, 12:01 AM
ok thanks
Old 07-11-2008, 10:31 AM
04600rr's Avatar
i am doing the same swap...........money wise it's easy.......it can cost a lot. Get on v8rx7forum.com. look into hinson super cars, Jags That Run, and a few others. They have everything need for the swap, but you pay out the *** for it..........Good luck with the build...you will love the finished product.
Old 07-11-2008, 02:03 PM
Skele4door's Avatar
You might want to reread my post and you'll note that I said "over there". I was referring to V8rx7forum which is where you'll find all the info you need.
Old 07-14-2008, 11:09 PM
FadedFD's Avatar
Here's mines if you want to check it out. I haven't updated in a while though.
https://ls1tech.com/forums/conversions-swaps/914990-07-ls2-94-rx7.html
Justin
