NEEDED: 2006-07 GTO Gauge Cluster wiring pinout?
Old 07-13-2008, 06:50 PM
mulletnotch's Avatar
Default NEEDED: 2006-07 GTO Gauge Cluster wiring pinout?
Just like it says if anyone can help I would really appreciate it. I need the wiring pinouts for the plug that goes into the back of the GTO gauge cluster. I have the plug and I have the cluster..... Just need to know how to marry them to my harness which already has the leads pulled and labeled.
Thanks in advance for any help!
Dave
Old 07-13-2008, 07:10 PM
lt4malibu's Avatar
Connector Part Information
• 9123-8265-30
• 32-Way Female (GY)
Pin
Wire Color
Circuit No.
Function
1
OG/YE
1340
Battery Positive Voltage
2
BN/WH
32
Instrument Panel Lamps Fuse Supply Voltage
3
Not Used
4
BN/WH
419
MIL Control
5
L-GN/BK
592
DRL Relay Control
6
GN/WH
1061
UART Serial Data (Secondary)
7-8
Not Used
9
OG
192
Fog Lamps Switch Signal
10
Not Used
11
BU
1315
Right Front Turn Signal Lamp Supply Voltage
12
BU/YE
1969
Headlamp/High Beam Relay Control
13
L-BU
1314
Left Front Turn Signal Lamp Supply Voltage
14
L-BU
264
Security Indicator Lamp Supply Voltage
15
OG
238
Seat Belt Switch - Left
16
Not Used
17
BK/YE
251
Ground
18
BN
897
DIC Switch Low Reference
19
Not Used
20
PK/BU
539
21-25
Not Used
26
PU/WH
5197
Cruise Control I/P Speed Signal
27
BN/RD
121
Engine Speed Signal
28
BU/BK
894
DIC Toggle Switch Signal
29
Not Used
30
BN/OG
33
Brake Warning Indicator Control
31
BN/WH
4
Accessory Voltage
32
GY/WH
746
Right Front Door Ajar Switch Signal
Old 07-14-2008, 01:39 PM
Smo's04Gto's Avatar
Lt4 is this the same for the 04 gto?
Old 07-14-2008, 02:24 PM
Chevy-art's Avatar
Thanks need this info also. Are all the years for thr GTO the same?
Old 07-14-2008, 02:27 PM
lt4malibu's Avatar
heres the pinouts for a 2004:
• 9123-8265-30
• 32-Way Female (BK)
Pin
Wire Color
Circuit No.
Function
1
OG/BK
1340
2
BN/WH
32
3
GN
875
ABS Indicator Control
4
BN/WH
419
MIL Control
5
L-GN/BK
592
DRL Relay Control
6
GN/WH
1061
7-8
Not Used
9
OG
192
10
Not Used
11
BU
1315
12
BU/YE
1969
13
L-BU
1314
14
L-BU
264
15
OG
238
16
Not Used
17
BK/YE
251
Ground
18
Not Used
19
BN
897
20
OG/YE
1340
21
GY
85
Cruise Control Engaged Signal
22
WH
396
23
Not Used
24
YE/RD
832
Traction Control Active Signal
25
BN
25
Charge Indicator Control
26
PU/WH
5197
27
BN/RD
121
Engine Speed Signal
28
BU/BK
894
29
Not Used
30
BN/OG
33
31
BN/WH
4
Accessory Voltage
32
GY/WH
746
Old 07-14-2008, 03:14 PM
AWESOME! Thank you!
Any easy way to tell which year a cluster is? I believe mine is an 06 but not sure now that I've been trying to recall when I bought it . LOL
Old 07-14-2008, 04:01 PM
Chevy-art's Avatar
Originally Posted by mulletnotch
AWESOME! Thank you!
Same here I bought one and I just don't know what year it came off of.
Old 07-14-2008, 04:50 PM
Smo's04Gto's Avatar
LT4MALIBU thank you so much great info. Would you happen to have any info on the engine wiring harness I'm
ready to convert the 04 gto engine harness to work in the nova swap.
Old 07-14-2008, 05:46 PM
lt4malibu's Avatar
PM me with what you need to know...
as for the clusters, i would need a part number to tell you what year it is.
Old 07-14-2008, 07:01 PM
Chevy-art's Avatar
Here is the part number: 92123211. Thanks for all the info and all your help!!!
Old 07-15-2008, 04:31 PM
lt4malibu's Avatar
thats not a good GM number...
-my catalog says 2004-2006 are the same unit, but theyre obviously wired differently. any other numbers on it??
Old 07-16-2008, 02:13 PM
Smo's04Gto's Avatar
part # on my 04 6spd
culster is 92123211
LT 012582-m and 8400-25152 is also on the unit
Old 07-19-2008, 08:11 PM
Chevy-art's Avatar
culster is 92123211
Here is what I got on mine: 92123211 LT 012766-M 8400-25152
The guy I bought it from says it came off of an '04 Automatic. I plan on using it with an LS1/4l60e combination, but now I am kinda worried. Hopefully it gets a signal telling it whether it is a 6 speed or an automatic. Thanks Art...
Old 10-05-2011, 05:46 PM
Dracer35's Avatar
Did anybody by chance get their gto cluster wired up and working? I picked up one cheap and was thinking about trying to use it in my swap project but if it wont work its not a big deal. I was told it was from an 04. Here are the part numbers I see on the back.
9218611
BT 021354-M
8400-25173
S/W Ver: 1.0.9
I did a search for the harness part number listed above but didnt find anything. I wonder if you can still purchase the harness peice or if you have to get a used one cut off a salvage car. Thanks in advance for any info.
Old 10-06-2011, 10:57 AM
TPI TERROR's Avatar
i bought a gto dash to fit into my 87 iroc. ive been researching but havent done it just yet due to lack of time. since im using the 02 ls1 im looking into the 04 gto mn12 cluster and pigtail.
does anyone know if the Driver information center module is needed to get the primary gauges working. i know that the DIC is mostly to get the LCD digital readings: avg mpg, digital speedometer reading, water temp, voltage etc
IIRC serial data gives out the signal for tach, temp and fuel etc. the vss for speed mph
years back i ran into a 64 nova engine build online. i don't recall him using a dic module.
anyone pull up the dic schematics? i might look into this later with the proper software
if you dont run the dic can you still get a digital mph reading . or just the gauges with needles?
Old 10-06-2011, 11:12 AM
kwhizz's Avatar
The cluster will show basic functions without the DIC switch....
Ken
Old 10-06-2011, 11:17 AM
kwhizz's Avatar
9218611
BT 021354-M
8400-25173
S/W Ver: 1.0.9
Heres a link to my build where we have the cluster working as per factory except for an ABS fault.........2005-06 cluster.......
https://ls1tech.com/forums/conversio...2-install.html
Ken
Old 10-07-2011, 02:27 PM
TTLS1GP's Avatar
Any chance you have the numbers of which control units you used?
Edit: I found this picture in your thread but cant read it...
What does "PIM" stand for? is it in the photo above?
Anybody know what the resistance values are for the factory sender?
Hope you don't mind but i posted that schematic here so people don't have to search through 26 or so pages...
Old 10-07-2011, 05:06 PM
kwhizz's Avatar
2006 GTO BCM........Body Control Module
PIM.........Parttrain Interface Module
Old 10-08-2011, 09:00 PM
TTLS1GP's Avatar
Is the PIM the black box in the photo?
I can find that part listed as a anti-theft box.
Quick Reply: NEEDED: 2006-07 GTO Gauge Cluster wiring pinout?
