Carb guys, what fuel pump/system are you running?
I stumbled across a few articles i was reading that made me re-think my fuel system. I know my holley 750 is fine. I had run 3/8" braided steel line which i thought was fine to a brand new stock fuel tank and sending unit. I also am running a 97gph holley red fuel pump with 3/8" fittings which i am not sure if that is going to be enough. What are you all running and what power levels? I'm looking for 400rwhp+ cam only, 450rwhp+ with heads, and spraying a 150shot on top of those. At what level do you think i will need a differnt fuel pump?
RCI 10 gallon fuel cell
1' of -12 braided hose
Magnafuel 300 with filter(900hp-NA)
-8 braided hose to inline filter
-8 braided hose to Barry Grant 4 port regulator
-6 braided hose to each fuel bowl
Speed Demon 750 mechanical secondary
I think your fuel system will be fine NA for sure. On the nitrous you might want to add another pump off a different port on your tank or go to a stand alone fuel system.
Even though I think my fuel pump would handle my engine and a 150hp shot I have a second -12 port on my sump that I am planning on running a holley blue going to a seperate regulator for the nitrous. I might do a stand alone up front, but I would really like to keep weight off the nose though.
You might want to look at the magnafuel pumps. They are some of the only electric pumps built for sustained use, and I can tell you first hand the quality is outstanding.
I have seen more than a few holley pumps overheat because they don't have a bypass and aren't ran with a return, and they aren't built for sustained use. For the price of them though you can go through several before you get to the magnafuel's.
Wow haha all that sounds overkill. I was going to go with an holley black but saw this one new on ebay one night and got it for like $20 to used with my pontiac 400/400 that was in it. figured id used it with this setup. I will be running dual widebands so i guess ill just run it and see if it goes lean WOT. Still havent installed my driveshaft, have it but i'm being lazy.
i run an A350 pump with large billet filter and integral regulator built in, -10 from tank to filter/pump and -8 return to tank. i then run a -8 to a carb regulator with two -6 out , one to each float bowl.
