Custom Air Intake Plumbing,,, Post Your Pics
Old 08-19-2008, 02:46 PM
Mikey 97Z M6's Avatar
Default Custom Air Intake Plumbing,,, Post Your Pics
Just like the title says, let's see some pics of those custom air intake systems. Give a brief description of what you used, size of hose and where you got the parts etc. I want to get some more ideas on where to locate the MAF and air filter for my conversion.
So let's see your custom air intake plumbing pics.
Mike
Old 08-19-2008, 03:11 PM
digitalsolo's Avatar
I have all 4" pipe and an 85 mm MAF, with a 90* straight off the TB and another 90 down to the MAF which is connected to the filter.
I don't think you'll have room for all that in an F-Body though. The RX7 has a much bigger engine bay.
Old 08-19-2008, 04:22 PM
bczee's Avatar
I have a chevelle so.. lot of room.. you may get something like it to work on a F-Body with a Cowl Hood ..
https://ls1tech.com/forums/conversions-swaps/643850-chevelle-cowl-induction.html
I used 90 elbow out of the T/B 4" to 3 1/2" to the MAF and then all 3 1/2" with another 90 and 45 elbow to my custom Air box/clean that seals to the Cowl hood and only draw air from the low pressure Cowl area.. and not any hot air from the engine bay.
Old 08-20-2008, 10:31 AM
philntx's Avatar
This is on my Blazer project:
4" aluminum pipe coming off C6 Throttle body:
Heat shield for 2008 TBSS Airraid filter that is mounted in upper drivers side corner:
Filter heat shield: (will also be insulate on inside and outside: MAF will be inside shield:
Bracket that holds the tube.
Scoop that uses the drivers side tow hook opening to get air into the bottom of the filter box
Old 08-20-2008, 11:11 AM
txredxj's Avatar
that is sexy right there
Old 08-20-2008, 12:27 PM
popeye's Avatar
Here is mine in a 47 Chevy. Hoses and the tube are all 4" with a K&N Filter.
This is just the start of assembly, car is at body shop getting a bunch of work done.
Old 08-21-2008, 04:52 PM
rockytopper's Avatar
I did a dual filter intake thru the front head lights. I originally wanted to do a Y tube with dual filters directly off the MAF. They have nice chrome ones on e-bay dirt cheap but I could not make that design fit the space. I ended up using assorted Lowes sewage piping and a coupler from JTR with some other eBay goodies and was able to get it plumbed. Turned out nice after I painted the pvc flat black. I am really amazed how much suction I get at the head light cones when I open the throttle.
Old 08-21-2008, 06:59 PM
ls1_chevelle's Avatar
Pretty simple air intake setup.
Old 08-21-2008, 07:05 PM
82z28macdady's Avatar
pretty straight forward, 4" to 3.5" bend to maf to 3.5" aluminum pipe to a 3.5" cone k&n filter.
Old 08-21-2008, 08:40 PM
SatisTraction's Avatar
Old 08-31-2008, 10:28 AM
Hotrod406's Avatar
Pretty straight forward on mine. NW 90mm throttle body with 4" aluminum 90 into a filter. Running Speed Density.
Old 08-31-2008, 10:56 AM
Aaron's Coupe's Avatar
Here is mine Intake, it is made all from parts at Pep-Boys. 4" 90deg elbo, small piece of 4" pipe, a reducer, my MAF then a open element filter. Clean and simple.
Old 08-31-2008, 08:52 PM
noregretz999's Avatar
https://ls1tech.com/forums/showthread.php?t=643850
where did you get that 4 inch to 3 1/2 inch 90 degree elbow from?
Old 08-31-2008, 09:01 PM
Kamin's Avatar
90 degree elbow
piece of 4" tubing from a billy boat exhaust i had lying around the shop
Reducer to MAF
AEM dry flow filter
Old 08-31-2008, 09:10 PM
Eddie 70's Avatar
Great ideas guys. Reminds me I need to get out there and work on my air intake setup. Tomorrow will be a good day to get at it.
Old 09-01-2008, 01:33 PM
LS1Diva's Avatar
I started with a Weiand manifold. Flipped it backwards, cut off the TB mount and fabricated the aluminum runner. This allows me to have a functional ram air hood scoop.
Attached Thumbnails Custom Air Intake Plumbing,,, Post Your Pics-intake.jpg   Custom Air Intake Plumbing,,, Post Your Pics-side-view.jpg
Old 09-01-2008, 08:33 PM
boondiggys's Avatar
that stuff looks promicing! keep it going!
Quick Reply: Custom Air Intake Plumbing,,, Post Your Pics
