L92 Intake Gasket #1222-2
Does GM or any other venders offer a intake gasket other than the fel-Pro
#1222-2 ? I had one hell of a time to get them off the head when I pulled the intake. They were stuck like they had been glued on (which they weren't)
Thanks
Thanks
1 Post
I suspect that you're going to run into the same thing that I have so many times - the engine is so new that virtually NO-ONE here is going to have any info. You post a question, & the only response you get is the sound of chirping crickets... (And I haven't even had time to fire my L92 up yet, so I'm not able to help you, although I sure would if I could...)
Best of luck though, I'd LOVE to be proven wrong...
why not make yor own out of some other gasket material using the old one as a template ??
or why not try to lightly coat the gasket surfaces with grase so it won't stick the next time?
