LQ4 VATS bypass . Which pin on the ECM to hook up to?
Hi everyone
I have a LQ4 out of a 2001 gmc Sierra 4x4.I know that on the F body cars on the red ECM connector pin #30 is the "fuel enable signal" but the Vats info from the BCM is transfered to the ECM by class 2 serial data link.On the pin out for the sierera connectors i can not find the "fuel enable signal" and the pin # 30 on red connector is not used .So where does the 50HZ signal from the vats bypass module have to go .Iam not sure where to go with this if anyone has good info i would be thankful
Thanks alot
John
Thanks alot
John
