I have a G Body and I have a 5.3l swap question
I have a 86 Buick Regal T-Type and I am just waiting for the engine to go(Which will be no time soon) But whenever it goes I want to do a 5.3 swap for sure. Now my couple of questions is simple. I walk into the junk yard and ask for what? The simple smartass answer is the engine and the tranny, well no ****. But do I ask for the 5.3l, the tranny that it came with, and all the wiring uncut? PCM? Fuse box? the obd adapter (what inside the car just incase it throws codes)? Just want to make it a easy and less painful swap. I have been reading pleanty of post but I want the stright answer.
Wow, what a nice attitude in the first post dude.
I'll give you a simple answer. Yes. Get as much from the donor car as possible. If you get the entire harness and fuse/relay center, you would just be able to hook your battery cable up to the lug, and splice your ignition switch, and drive off.
All you have to do is a little searching on here. G-body's are a popular swap. More info than you will ever need.
Oh my god man....I wasn't using an attitude in my post. Since I am deployed I have been running a list and talking to my counter parts around here on how to make this a easy to do in one day swap. I been searching the threads for a couple of weeks now. I been on this site many times since i bought my 04 GTO and never registered. Though it might of been my first post doesn't make this my first time to post on a forum nor does it make me a little 15 year old noob kid. I am on many other forums and I do not us my post count to repersent my knowledge of the all might LS1, LC2, or any other. I ask for a simple question and maybe it will help out others to just take a list and hand it to the worker at the junk yard and bam easy transaction. thank you for your info
I never said anything about your post count, or how long you've been looking without joining. I guess attitude was the wrong word, I guess use of swear words should have been the phrase.
I trying to come across like you were a lazy noob kid, I'm sorry if I did. I was just pointing out that G-body's are popular on here, and your question has probably been asked and answered 20 times.
Sorry if I came across as a jerk.
I think lowerred covered it pretty well. Pretty much get as much from the donor car as possible. Engine,tranny,harness,computer, exhaust manifolds with some of the exhaust still attached if possible. This way you can use as much as you want and sell the rest to recover some of your initial cost. The ALDL connector from any OBD II car can be used and does not need to be from the donor car. I know how you feel with being deployed and trying to put together a project. My best advice would be to search for related posts, print off any lists with part numbers and such or if not available put together a list of parts with part numbers, prices, and vendors to help get everything planned in some order. This will make the whole process alot easier and always a reference to go back to and check. Good Luck out there Brother!
200R4? Head up to Automatic Transmissions, and click on the search box, I did 200R4, and a bunch of red topics popped up.
I honestly couldn't help you out there. I just used the 4L60E that came with mine.
If it's to save money, my quess would be it would be cheaper to use a 4L60E than to get swap parts for the 200R4.
you can use the stock 2004r with your engine. I belive you have to leave one of the bellhousing to engine bolts out. There is also a spacer that mates the stock flywheel to the 2004r convertor. Then there is the whole tv cable deal. You are going to have to fabricate a bracket to mount the end of the cable to the throttle body that will give you the proper geometry for it to fuction properly.
I saw that on turbobuicks.com
I am only doing the swap if the motor ever goes south. These little turbo 6s are expensive. I figure I will not be even spending half the amount to do this swap as I would be spending to do another v6 or even rebuilding it. I will sell this T-Type of you want it. I am just gathering up info on this swap because it has my mind wondering. There is nothing wrong with the engine right now.
When I get started on my Monte I plan to keep the 2004R and run a megasquirt. I think that will simplify alot.
I've been studying the same thing for the future buildup of my Monte SS. Keeping your 2004r will have a few benefits. With the 4L60 you will no longer have the gear for your stock speedometer cable, its also a diffrent length which requires a new or modified driveshaft. With your 2004r, you don't have those issues. The way I understand it, the biggest issues are the TV Cable and the lack of a vehicle speed sensor in the 2004r. There are aftermarket solutions for both.
