TQ converter in light weight car?
Old 10-01-2008, 03:57 PM
silver86's Avatar
Default TQ converter in light weight car?
I am doing a Ls1 into a car that will weigh about 2100lbs. I am going with ported 243's a LS6 intake and havent decided on the cam yet. I was thinking about the MS3 but not positive. I know that the cam and stall go hand in hand but I also thought vehicle weight was a factor also.
What kind of converter/stall would be a good choice for a swap like this. Or is there any site recommended to learn how to pick my own stall.
Thanks.
Old 10-02-2008, 01:27 PM
Oscar Will's Avatar
The converter manufacturers are usually pretty good at sizing a part for you.........a vehicle that lightweight is going to call for alot of stall to be drivable.
I have a friend with a very light roadster, similar weight to yours, he has a pretty well modded LS1 with about 3500 rpm stall. It works pretty well.
Old 10-02-2008, 04:11 PM
lt4malibu's Avatar
what kind of trans??? your cam, rear gear, overall tire diameter and weight all help make the decision. i would guess around 3500-4000.
Old 10-02-2008, 06:13 PM
silver86's Avatar
4l60e, I think I am going to go with either a ms3 or ms4, I will be running a 28 X 13.50R15, rear gear will be a 3.55 and max weight will be 2300lbs.
I may just call a converter company and see what they say. I would like to understand myself though what calculations they use to determine a suggested stall.
Thanks
Old 10-02-2008, 07:52 PM
lt4malibu's Avatar
Thanks
i reccomned YANK performance, i had another converter before theirs and it took 2 "re-stalls" and it still wasnt right, yank hit it first shot.
my car weighs 3050, has 373's, a cam similar to the MS3(in an otherwise stock motor)and a 26x10 and i have a 4000 stall, with the 355's and taller tire you may want a little more unless you're spraying it...
Quick Reply: TQ converter in light weight car?
