f-body oil pan modification
Old 10-09-2008, 07:06 PM
69importkilla's Avatar
Default f-body oil pan modification
Just a quick question. Putting a LSX in my 69 Camaro. I got the f-body pan and pick-up. I modified the pan, but how did anyone go about modifing the pick-up? Cut and weld, heat and bend? Suggestions?
Old 10-09-2008, 07:38 PM
12thstreetjunkman's Avatar
here is what mine looks like, this is an f-body tube, the truck tube is the right length, you would just need to an inch or so from where it starts to turn down to the pickup.
Old 10-10-2008, 12:35 PM
bczee's Avatar
As you guested.. Cut and weld, heat and bend if needed... Just make sure the the flange and o-ring sits flush and seals correctly.
Old 10-10-2008, 01:43 PM
DGGM WX3's Avatar
Do you need to modify a F-body pick up tube to work with a notched F-body pan?
That picture looks like the pick up isn't even affected by the notch.
Old 10-10-2008, 02:03 PM
The pickup was lengthened about 3 1/2" if you can see the pipe in the picture, it is kind of hard to tell. I bought this pan already done, it was sopposedly copied from a s&p modified pan. There is another 1st gen running around here local, he did the pan himself and had to lengthen the pickup as well.
Old 10-10-2008, 04:16 PM
leonpiper69's Avatar
i just used a gentle couple of taps with a rummber mallet to move it over a hair, wich caused the pcikup to be crooked slightly. so then i gently staightened the pickup. fit tight, but good oil presure and no signs of trouble.
but i dontthink i chopped out as much of the pan as you did.
Old 10-10-2008, 11:17 PM
DGGM WX3's Avatar
How many inches in each direction did you take out?
Old 10-10-2008, 11:50 PM
about 2 inches (but it was a couple years ago)
Quick Reply: f-body oil pan modification
