Convertible Vehicles Enthusiasts | Information | Maintenance
applique
Old 02-24-2013, 09:31 AM
george88gta's Avatar
Default applique
Noticed the small triangular piece, behind the drivers side door glass ( called an applique) is starting to come loose. New one from GM is around $100. What holds the plastic piece to the rest of the weatherstrip part? Anyone have a fix? I was thinking that if I can get it removed, without breaking the part,I could use some 3M weatherstrip adhesive to reattach. Any ideas?
Old 03-02-2013, 01:03 PM
Chevyguy2001's Avatar
probably should work.
Old 03-02-2013, 03:55 PM
TEXASLESS's Avatar
3M tape....Took both off and polished and 3M back on...
Old 03-02-2013, 09:45 PM
Both good ideas. Am I correct in thinking that they were just glued on originally and a slow/careful removal process should work?
Old 03-08-2013, 05:27 PM
ALT-F13's Avatar
Yes, you are correct.
I've removed mine for painting, no issues.
Old 03-10-2013, 03:17 PM
Removed and back on. I decided to go with the 3M tape, less of a chance of making a mess. Thanks guys.
Quick Reply: applique
