Top starting to lift from top of the rear glass!
I have used 3m double sided tape. Available at auto zone. Need to clean glass and top with alcohol very well. Took me 20 min to do. Lasted for a few seasons. I replaced the entire top eventually.
I know this is an old thread, but if you didn't fix it yet try window weld. It is a black adhesive in a caulk like tube. My window was almost completely off and that reattached it no problem.
rear window loose
I tried double sided tape applied from inside the car. Came loose after a couple of up and downs. I then applied it from the outside the glass and under the top. It is holding after several up and downs.
