Anyone sound deaden a vert?
Fellow 'vert owners...
I'm looking to quiet up the interior a little. I do drive with the top up on occasion and the car really sounds like a tin can.
I think I have realistic expectations - it's a 'vert; I don't expect it to be a tomb inside.
My question is for anyone who's done it - what areas should I focus on? All of it? I am debating between basically doing the vertical surfaces only (doors, quarter, package shelf, etc) or if it's worthwhile to pull up the carpeting and do the entire floor as well.
I have not done this, but plan on it later this year. IMO you should pull up the carpet and do the floor, and trunk area as well as the doors.
Im betting it would make a huge improvement.
From what I am reading, the CLD tiles (dynamat, etc) are only needed to cover a portion of panels that reverberate.
I am leaning towards the sound deadener showdown tiles. He recommends 25% coverage, so I'd be looking at approximately 60 tiles for full coverage. That's roughly $155 shipped.
I have a foam outlet near me, so I was planning to pick up polyethylene foam for a decoupler. If I am satisfied, I stop. If I am not, I can get some MLV to lay down on top of the foam...should run me around $200 for the MLV.
If/when I pull the trigger, I'll let you all know what my experience and impressions are in a 'vert.
im not sure i would do the doors on any camaro vert or not, there already big heavy doors know for cracking at the hinges. adding more weight to it will only make them crack even faster
My car was done by the previous owner. The trunk, doors and under the carpet. I rarely drive with the top up because my car is a toy or weekend driver but when I have, I still think it is loud. Keep in mind, I have no idea how loud it was before the sound deadner was installed.
I had a convertible at one time that was done with 1/2" insulating foam blanket. It was closer to carpeting. It was everywhere from the inner passenger door panels back into the trunk. Couldn't have cost all that much to buy the material. Don't know how it worked as I immediately removed it all as soon as I got the car. And 10-15 years later I still find uses for that stuff that came out of the car for projects around the house. I've had 3 verts and never thought any of them were rattlely. Then again, you get used to them.
Have a Vert, but not sounded deadened. However I did sound deaden my Firebird, every square inch I could with Dynamat. Inside the door shells and on the door panel portion itself. Add a layer of Ensolite foam, studio quality ****.
Get everything back together and didn't notice a damn bit of difference. Leary to bother with doing it to the Vert, feels like a waste of money and extra unnecessary weight for the Bird.
