97 Z28 convertible top pump rebuild info
HI everybody! New guy here. Lovin' the convertible category to this forum!I've got a 97 Z28 convertible. Had it for almost 2 years now. Recently noticed the top making a noise when I put it down, so I looked in the back at the pump to make sure I had enough fluid in the reservoir. It's still at a safe level but it is down a bit. Then I noticed a puddle of fluid on the base under the pump. Absolutely dry at all the tubing and fittings so I can only assume it is leaking from the pump or tank somewhere. Does anyone have a DIY instruction on repairing this unit? I would assume it's just some O-rings somewhere and if I begin disassembly carefully I will figure it out. Appreciate any info! Thanks!
