Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Want to drop Z even lower
Old 12-25-2008, 03:04 PM
TransAmcoupe98's Avatar
Default Want to drop Z even lower
I've dropped my vette as low as I can on those stock bolts. What would I have to do to get the thing slammed? Would I need to buy aftermarket lowering bolts, where and how much are these bolts?
Old 12-25-2008, 04:16 PM
rzuff's Avatar
For the rear you can go to the hardware store and buy grade8 bolts that are longer then your stock ones. For the front you can remove the adjuster bolt. You should buy Bilstiens or shorter shocks because the lower you go the less travel you have.
The best would be coilovers which I have but they are a few $$$$
Old 12-26-2008, 02:22 PM
I'll be using the grade 8 bolts for the rear. As for the fronts, you just remove the bolts, will the tires scrub the fenderwells when u go over a bump or launch at the track?
Old 12-26-2008, 02:26 PM
So Slow's Avatar
Here is a picture of my coupe with the lowering bolts removed and Bilstiens...
Old 12-26-2008, 05:15 PM
Do I have to use the bilsteins???
Old 12-26-2008, 08:44 PM
c6r
c6r's Avatar
Here's picture of my car with lowering bolts, I did not know you could go lower with out the coil over setup. click to enlarge image.
Quick Reply: Want to drop Z even lower
