Heads for my setup
Heads for my setup
I need suggestions for heads given my setup. This is for a 98 C5 6 speed. I'd like to stay around $1,500 or less. I'm looking for power under already have spings/pushrods. Whats the next step up from LS6 heads? Patriot, PRC? Should I just get the LS6 heads? Also, my friend doing the install has LS7 lifters, is there any benefit of using these in my car?
Mods:
Texas Speed 228R 114LSA Camshaft
PRC Platinum Double Springs
Hardened 7.40” Chromoly Pushrods
LS6 Intake Manifold
BBK 80MM Throttle Body
ProFlow+ Cold Air Induction
Breathless Performance Increase MAF Sensor
HighFlow 172 Thermostat/Housing
Throttle Body Water Bypass
TPIS Long Tube Headers
Pro Flow X-Pipe & High Flow Catalytic Converters
B&B Tri Flow Sport Mufflers
Racetronix Boost-A-Pump
LS2 Oil Pump
Timinig Chain
Catch can
3.90 Rear Hardened Axle Seals/Gears
Z06 Clutch
Throw Out Bearing
Clutch Master Cylinder
Hurst Short Throw Shifter
Mods:
LS6 Intake Manifold
LS2 Oil Pump
Timinig Chain
Catch can
Z06 Clutch
Throw Out Bearing
AFR 205's.
Not your budget, I know but,...take it from a douchebag thats spent alot of money, more then once, on the same products.... then ended up buying what I really wanted in the end.
Any of the heads you mentioned would work but, the 205's would rock that setup of yours pretty well.
AFR 205's.
V-series has some for sale. Budget heads are your "as-cast" heads that are ported. A good majority use the PRC 2.5 LS6 heads. They are in the $1500. With those heads, you get a .5 compression bump. You would end up with a 25-30 whp increase with those heads. Your higher dollar heads : AFR, TFS, will net you quite a bit more than the as-cast selections. Not to mention, AFR 205's are emissions legal if that is a factor.
