98 turbo c5
98 turbo c5
I have a bone stock c5 with a 76 mm turbo and 9 psi with 60 pound injectors will the stock fuel system feed this setup. IF not what do i need.
You would need to upgrade to an intank pump setup. Do you have big plans for the car, or are you trying to budget> Only ask cause if you can do it right the first time, you'll save money on parts and labor. But, since you asked if the stock feed will work, the answer is You would need to upgrade to an intank pump setup. Like the racetronix pump and hot wire kit. It's pretty much a walbro 255 stock replacement. The hotwire kit increases voltage to the pump under load.
That setup with stock injectors will get you SAFELY to 700-720rwhp. ANy more power, and at 5000ish rpms, you'll loose pressure.
