We're Baaaack :) www.PartsTaxi.com Corvette Specials
Closed ex-Sponsor Account
Please keep in mind we are a full line GM dealership, if you don't see a part listed that you need, for any GM vehicle, please contact me via;
Email - kevin@partstaxi.com or parts@partstaxi.com
Phone - 302-883-0227 or 302-645-6221 x126, 124, 125, 122
YahooMessenger And AOL Instant Messenger; Screen Name PartsTaxi
I have linked a majority of these specials directly to their pages on our website with more information. Please click on the part number or description where available.
19170234 - GM Genuine Accessory Splash Guards - $90.95
19116372 - GM C6 Fuse Block Cover - $29.98
Genuine GM C6 Corvette PAL
17800593 - C6 Corvette Personal Audio Link - $139.58
--------------------Interior Upgrades------------------------
IT'S OFFICIAL - HEADS UP DISPLAY COMPLETE KIT - $369.74[/COLOR]
Click on the name of the kit to link directly to our site to order.
This kit includes;
HUD Display
HUD Switch
HUD Bezel
Custom Wiring Harness
2 6mm nuts needed for install
Detailed Instructions
2008 & Up Two Tone Interior Seat Covers
Ebony/Titanium Two Tone - $919.25
Ebony/Cobalt Red Two Tone - $899.25
Ebony/Cashmere Two Tone - $899.25
We have now added the option for you to re-use your existing cover for the center of the seat back. Doing this will save you $250 and is an option at check-out so you see the correct price! This has become a very popular option.
Outer Back Seat Covers with Cross Flag Logo - Available in Ebony, Cashmere, Cobalt Red and Titanium - $239.47 for the pair!
Above listings require sport seats not normally found in 1LT cars. If your not sure what seats you have please call or email with VIN and we can check for you.
----------------C6 Maintenance Common Replacement Items---------------
Filters
12626224 - Single UPF48R Filter - $8.68 each
To order a case of 12 UPF48R use Part Number 12packUPF48R for $103.47 total (thats $8.62 each!)
25329389 - UPF44 Oil Filter $8.68 each
89017524 - PF48 Oil Filter $4.46 each
19210283 - PF46 Oil Filter $4.46 each
15861929 - Passenger Compartment Filter - $45.89
10342024 - LS2 Air Filter Element (Need 2) - $16.42 each
15776148 - LS3 & LS7 Air Filter Element - $84.44 each
25940997 - LS9 Air Filter Element - $111.87 each
Tune Up Parts
GM Performance Parts Red 8mm Wire Set - 12495519 - $54.39
LS2 & LS3 Iridium Spark Plug - 12621258 - $5.98 each
LS7 Iridium Spark Plug - 12571165 - $5.98 each
Serpentine Belts
LS2 & LS3
A/C Belt - 12579228 - $16.30
Main Drive Belt - 12579229 - $29.34
LS7
A/C Belt - 12585476 - $15.82
89017847 - Starter - $258.66
25888970 - Alternator - $305.12
-----------------Suspension Upgrades------------------------
20822934 - Upgraded Metal Sway Bar End Links - $22.78 each
Z51 Front and Rear Sway Bar Kit - Our most popular bar kit. Kit includes front and rear stabilizer bars and bushings for Z51. We are now proud to offer our customers the choice or either OEM bushings, or polyurethane (poly) bushings from Pfadt Racing for the same price of -$192.21
C6 Z06 Shocks - In Stock!!
10313647 - Front Shock - $59.42 each
25819268 - Rear Shock - $58.54 each
That's only $235.92 for all 4!!
T1 Springs
Front - 25534418 - $832.38
Rear - 25534419 - $832.38
--------------------Brake Upgrages-------------------------
Z51 Brake Upgrade Kit - Kit includes both front rotors, both rear rotors and all four caliper mounting brackets - $499.84
Ceramic Brake Pads for Stock and Z51 systems - NEW LOWER PRICE!!
88909667 - Front Ceramic Pad Kit - $59.84
88909668 - Rear Ceramic Pad Kit - $39.84
That's only $99.68 for all 4 wheels!!!
Base C6 ACDelco Drilled & Slotted Rotors
19183532 - Right Front - $64.90
19183533 - Left Front - $64.90
19183534 - Right Rear - $62.71
19183535 - Left Rear - $62.71
That's $255.22 for all 4!!!
Shipping will be adjusted to actual cost. Normally between $28-$45, depending on your location in the US.
LS7 Clutch Kit - Kit includes LS7 Clutch and Flywheel - $431.97
--------------------Exhaust Upgrades---------------------
NPP Exhaust now readily available!
2008 & down = $1240/pair
15879289 = $620
15879288 = $620
ATTENTION - 2008 NPP GROUP BUY EXTENDED - $1175 FOR THE PAIR LISTED ABOVE. ORDER THROUGH THIS LINK.
2009 & Up = $1378/Pair
25839149 = $689
25839148 = $689
----------------Popular Upgrades & Accessories-----------------
All accessory part numbers are listed under the "Chevrolet" make when searching by part number from our home page.
Transparent Removeable Roof Panel - 12499572 - $1199
Transparent Roof Panel Storage Bag - 12499749 - $59.80
Transparent Roof Panel OEM Replacement - Glass panel, no hardware. You can transfer your hardware from your existing painted top - 25808856 - $557.29
Shipping on this roof is normally between $60-$70, depending on your location.
Under Hood Lamp - 19165567 - $31.90
Engine Performance Data Plates
LS2 - 19154739 - $33.89
LS7 - 19154740 - $31.89
Full Width Design Spoiler - Special Carried over!
19172807 - Primer - $229
19172808 - Victory Red - $259
19172809 - Velocity Yellow - $259
19172810 - Machine Silver - $259
19172811 - Black - $259
19172812 - Jetstream Blue - $259
19172813 - Crystal Red - $259
19211166 - Cyber Gray - $259
19211165 - Switchblade Silver - $259
19211167 - Atomic Orange - $259
This kit includes;
HUD Display
HUD Switch
HUD Bezel
Filters
Tune Up Parts
Serpentine Belts
LS2 & LS3
LS7
T1 Springs
15879289 = $620
15879288 = $620
25839149 = $689
25839148 = $689
