August C5 Specials - www.PartsTaxi.com
Closed ex-Sponsor Account
2010 C6 Shifter Kit
25823572 - Shifter - $120.41
15851631 - **** - $61.86
11609670 - Bolt - $2.72
Total Kit $185.04
This kit works on all C5's but you will need to modify your boot during installation to fit. Or, of course you could purchase an aftermarket boot.
Genuine OEM GM C6 LS7 Clutch Kit
LS7 Clutch Kit - Kit includes LS7 Clutch and Flywheel - $419.52
LS6 Slave Cylinder - 89059282 - $125.01
LS6 Master Cylinder - 12564455 - $136.93
Pilot Bearing - 14061685 - $11.99
Clutch works with all C5 drive train but must utilize LS7 flywheel provided in kit.
C5 Maintenance Parts
12621258 - Iridium Spark Plug - $5.99each
12495519 - GM Performance Parts Red 8mm Spark Plug Wire Set - $54.39
10287788 - 1997 & 1998 Fuel Filter - $12.18
19239926 - 1999-2004 Fuel Filter & Pressure Regulator - $73.06
25042562 - 1997-2004 Air Filter - $11.88
12572188 - Serpentine Belt - $44.82
19172680 - A/C Compressor Belt - $44.20
12559325 - A/C Belt Tensioner - $68.88
25329389 - UPF44 Oil Filter - $8.68 each
19210283 - PF46 Oil Filter - $4.46 each
GM Keyless Entry Transmitters/FOBS
10253839 - For 1997-1999 - $69.38
10432147 - For 2000 Only - $54.68
25695954 - For 2001 - 2004 #1 - $54.68
25695955 - For 2001 - 2004 #2 - $54.68
C5 Tire Pressure Sensors
25773946 - 2001 - 2004 Sensor - $38.98 each
25981210 - 1997 - 2000 Sensor - $91.88 each
15234846 - 1997 - 2004 Nut - $3.69 each
GM C5 Ceramic Brake Pads
88909667 - Front Ceramic Pad Kit - $65.75
88909668 - Rear Ceramic Pad Kit - $44.13
C5 Z06 Brake Pads
19181427 - Front Pad Kit - $126.76
12530688 - Rear Pad Kit - $57.65
ACDelco Performance Drilled/Slotted Rotors
19183532 - Right Front Rotor - $64.90
19183533 - Left Front Rotor - $64.90
19183534 - Right Rear Rotor - $62.71
19183535 - Left Rear Rotor - $62.71
That's only $255.22 for all 4 rotors
OEM Brake Rotors
10445856 - Right Front - $49.95
10445857 - Left Front - $49.95
10445858 - Right Rear - $49.95
10445859 - Left Rear - $49.95
That's only $199.80 for all 4!!!!
Z06 Brake Calipers (Red)
Left Front - 88895128 - $121.59
Right Front - 88895129 - $121.59
Left Rear - 88895130 - $89.19
Right Rear - 88895131 - $89.19
Complete set for only $421.56
C6 Z06 Brake Upgrade Kit
Kit includes both front calipers, both rear calipers, both front rotors, both rear rotors, front and rear GM OEM pads. We prefer not to substitute ACDelco as a replacement on this kit. - $1942.67
C5 Z06 Brake Ducts & Screens/Scoops
Screens/Scoops
Left Front - 10424821 - $89.16
Right Front - 10424820 - $89.16
$178.32 For the front pair
Left Rear - 10322761 - $77.80
Right Rear - 10322762 - $77.80
$155.60 for the rear pair
Brake Ducts
Left Front - 10295976 - $22.75
Right Front - 10295977 - $22.75
$45.50 for the front pair
Left Rear - 10425976 - $22.80
Right Rear - 10425977 - $22.80
$45.60 for the rear pair
All 4 Screens/Scoops and Ducts $425.02
20822934 - Upgraded Metal End Links - $22.78
GM Has now updated all C5 & C6 to the metal end links. These are a direct replacement. These all metal end links are an easy replacement and will solve the common "clunk" noise
C6 Z51 Front and Rear Sway Bar Kit
Our most popular bar kit. Kit includes front and rear stabilizer bars and bushings for Z51. We are now proud to offer our customers the choice of either the OEM GM bushings or the poly Pfadt bushings for the same price! - $192.21
C6 Z51 Sway bar kit will work on C5 with no modification needed
C6 Z06 Front and Rear Sway Bar Kit
Kit includes Front and Rear Stabilizer Bars for C6 Z06 and insulators - $219.85
C6 Z06 Sway bar kit will work on C5 with no modification needed
C6 Z06 kit is not recommended for use with rear tire sizes under 315. Any smaller then a 315 tire, these will cause the rear to wash out.
C6 Z06 Shocks
10313647 - Front Shock - $59.42 each
25819268 - Rear Shock - $58.54 each
All 4 Shocks for $235.92
C6 Z06 shocks will work on C5 with no modification needed
C5 Z06 Shocks
10339944 - Front - $101.78 each
10339945 - Rear - $121.76 each
Complete set for $447.08
C5 Z06 Springs
15233396 - Front - $247.86
22188038 - Rear - $531.48
T1 SACHS Shocks
Front - 12480094 - $162.27 each
Rear - 12480095 - $162.27 each
That's $649.08 for all 4!
T1 Springs
12480063 - Front Spring - $829.44
12480064 - Rear Spring - $829.44
T1 Sway Bar Kit
T1 Sway Bar Kit consists of F&R T1 Bars and bushings - $559.10
Add Fully adjustable T1 End Links for $219
Or
Add C6 Metal End Links for $91.12
12480062 - C5 Corvette T1 Suspension Kit - $2957.20
~Developed and approved for SCCA Touring 1 racing
~Comprehensive kit dramatically improves the handling of the Corvette
~Includes front and rear springs, front and rear stabilizer bars, stabilizer
bar end links and isolators, upper and lower front A-arms
Genuine GM Replacement Sport Seat Pads/Foams
2001-2004
10273418 - Driver & Passenger Seat Back Outer - $34.80 each
10283891 - Driver & Passenger Seat Back Insert - $69.47 each
10273420 - Driver Seat Cushion Pad - $79.80
88991516 - Passenger Seat Cushion Pad - $58.17
Complete Set of 6 Foams/Pads = $346.51
1997-2000
10273418 - Driver & Passenger Seat Back Outer - $34.20 each
10273420 - Driver & Passenger Seat Cushion Pad - $79.80 each
Complete Set of 6 Foams/Pads = $369.14
GM Performance Parts Cams - Please click on the links to view exact cam specs.
Hot Cam Kit - comes with Hot Cam, 16 LS6 Valve Springs and Retainers - $468
GM Performance Hot Cam - 88958733 - $399.71
GM Performance LS Stage 2 Cam - 88958722 - $399.71
GM Performance LS Stage 3 Cam - 88958723 - $399.71
Pontiac GTO Space Saver Spare Rim - 92156731 - $75.88 each
Lots of people like to use these as a light weight front rim for drag racing. Rim does not come with tire.
OEM GM Intake Manifold
Intake Manifold Only - 88894339 - $464.16
Coolant Pipe - 12602544 - $37.69
Coolant Plug (need 2) - 12602540 - $6.23 each
Total only $514.31!! I refuse to mislead my customers with combined pricing, I prefer to list everything individually. Shipping on these 3 items anywhere in the continental US will be anywhere from $15-$22.
Thank You!
Kevin Cassimore
www.PartsTaxi.com
Total Kit $185.04
C5 Z06 Brake Pads
OEM Brake Rotors
Screens/Scoops
Brake Ducts
C6 Z06 Shocks
C5 Z06 Shocks
C5 Z06 Springs
T1 SACHS Shocks
T1 Springs
T1 Sway Bar Kit
Or
2001-2004
1997-2000
Thank You!
Kevin Cassimore
www.PartsTaxi.com
