Need Help ASAP With Under-Drive Pulley!
I am just finishing up my cam swap and did a SLP Under-Drive Pulley along with it. But the main belt they tell you to get on the directions and website is a Gates 6PK1900 or Equivalent but it is too short and dose not work???? So did anyone know why or have this issue. I need my car up and running today so the sooner I can get some hep the better. Thanks in advance. Also this is for my 2002 Z06.
Here is the link to the UD Pulley.
http://www.slponline.com/view_product.asp?P=100225
Not sure about the SLP pulley but with the ASP pulley it takes a 77.5" long belt for the main drive and a 39.5 for the AC. The belt you are showing is a 74.8. That would be definitely too short if you had the ASP. Try the 77.5 and see if it works. A Good Year Gatorback number is 4060775.
I was just told this would work as well. Thanks a lot guys.
It hit me right after i posted this and I looked on the Texas Speed and Performance website and got the belt they recommend for the ASP and what do you know it worked (the775 you told me about). I don't know why SLP has the wrong one on there website and for the directions.
Yes you are correct the Belt SLP recommended for the A/C worked perfect I did not use the ASP one for that just the Main Belt.
