Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
HR LS2 402 C6 Corvette 560rwhp 504rwtq
Old 10-19-2010, 08:51 AM
Closed ex-Sponsor Account
JHR Performance's Avatar
Default HR LS2 402 C6 Corvette 560rwhp 504rwtq
We just finished up Jeffs (the owner of the shop) 2005 C6 Corvette. We were pretty happy with the results and I believe they speak for themselves. Look how consistant this thing is!!
All runs were done with all the belts on, 30psi in the stock sized Nitto Invos, and air filter in. Just as it was driven on the street. These numbers were made on 93 pump gas.
First time at the track we ran 10.38 @ 136.
Here is a run down of the build.
HR/G Engines LS2 Based 402
12:1 Compression
Callies Dragonslayer Crank
Compstar Rods
JE Pistons
AFR 225s Ported by Tony Mamo
11/32 PR's
Jesel Mohawk Valvetrain
Morel Lifters
HR/Tony Mamo Custom Comp Cam
FAST 102 Ported by Tony Mamo
NW 102mm TB
GZ Motorsports Vacuum Pump
Callaway Honker CAI
EWP
ATI 10% Underdrive
60lb Injectors
Mcleod Twin Disc Clutch
Quick Time Bellhousing
NW Adjustable Master Cyl.
Phadt CF Drive Shaft
Phadt Mounts
RPM 6060 Trans
RPM 3.42 C6Z/ZR1 Diff
Kooks Stepped 1 7/8 to 2 Inch Headers
3" Kooks Mid Pipe
Magnaflow 3" Catback
QA1 Coilovers
CCW 17 in Drag Pack
SD Tuned by Nick Williams of HR
This is only the first stage of this build, rings were gapped for a healthy shot of nitrous
Dyno Video
http://www.youtube.com/watch?v=ifUfBRQLbDw
A few pictures of the car...
Zach
Old 10-19-2010, 09:40 AM
pittman's Avatar
Nice...when is that thing hitting the track ? Would love to see some NA results
Old 10-19-2010, 09:45 AM
First track day is set for Nov. 13th at Darlington. Have to get it aligned, and a set of track wheels and tires.
Zach
Old 10-19-2010, 12:15 PM
pittman's Avatar
Zach
I wish you some 42 degree air....some -1000 DA
Good luck man !!!
Old 10-19-2010, 12:45 PM
Good luck man !!!
That would be great to have for sure!!
Thanks!
Zach
Old 10-20-2010, 02:33 PM
marc97taws6's Avatar
Looks damn good! Excited to hear track #'s
Old 10-20-2010, 05:03 PM
NoTractionLS1's Avatar
Damn thats my favorite color for the C6's. Thats some nice numbers. If all goes well it should pull some good times. Just make sure you have the driver mod
Old 10-21-2010, 07:43 AM
We will have some before too long!
Should run low 10s at 130-133 is what I am thinking. Driver mod is already installed!!
Zach
Old 10-21-2010, 07:58 AM
pittman's Avatar
Zach
That should be spot-on if the air and sixty foot are good
Old 10-21-2010, 10:15 AM
We will see...wheels and tires were ordered yesterday along with the vacuum pump!
Zach
Old 10-21-2010, 01:36 PM
pittman's Avatar
Zach
I just put the GZ vaccum pump on my Silverado 402...those are great guys to work with. I didn't have a direct fit so they sent me xtra parts a couple times. I saw some power under the curve on the dyno. Ran it last night in Gainesville...worked flawlessly !!!
Old 10-21-2010, 02:07 PM
Yeah, we have used them in the past. There is one on Nicks car, along with a solid roller 427 we have completed. We also have them on a few of our blower cars.
Zach
Old 11-12-2010, 02:16 PM
Update...Ran 1/8th mile for a little testing last night and went:
1.50
6.60
106mph
We will update after we run the quarter tomorrow.
Old 11-12-2010, 04:26 PM
scramblerman's Avatar
nice build and awesome numbers from a 402.
Old 11-16-2010, 07:32 AM
Thanks man.
Zach
Old 11-16-2010, 07:35 AM
pittman's Avatar
106 mph
Gonna be a low-low ten for sure, at least !!
Old 11-16-2010, 10:38 AM
david vericker's Avatar
1.50
6.60
106mph
Did you make those 1/4 mile passes on 11/13/10? The 1/8 mile results looked stout!
Old 11-16-2010, 01:49 PM
10.30s with a mid 1.50 60' at 136mph! We have a little suspension work to do, but the mph is promising. I would like to see it on down in the low 1.4s. BTW car weighed 3360 or there abouts with Jeff driving.
Zach
Old 11-16-2010, 01:50 PM
n2o402's Avatar
Default Ls2
Great job good numbers got a 402 I'm breaking in now no dyno numbers yet.
Old 11-18-2010, 02:00 PM
SouthTexasBully's Avatar
awesome #'s and great track results...136 mph trap is impressive..STB
Quick Reply: HR LS2 402 C6 Corvette 560rwhp 504rwtq
