Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
345/40/18
Old 01-23-2011, 10:13 AM
Midnight00SS's Avatar
Default 345/40/18
Will these tires fit no problem on a 99 corvette thats lowered 2 inches?
Old 01-23-2011, 01:45 PM
anyone?
Old 01-25-2011, 12:15 PM
T-REZ's Avatar
wondering
Old 01-25-2011, 12:23 PM
IAmTheSTIG's Avatar
not without a minitub or lewis 5 wide fenders, a search would have resulted that.
Old 01-25-2011, 02:58 PM
LSOHOLIC's Avatar
Not even close !! First of all you would need a 12-13" wheel, factory C6Z stuff or aftermarket wheels. Then they would stick out 2-3" past the fender. Not to mention they are almost 29" tall.
Like the previous poster said, L5's, TPE's or minitub. That 3:15 gear with a 29" tall tire, you better be putting down some serious HP to even get it moving.
Stock Tire - 345/40R18 >Search Tires
Section Width: 13.58 in 345 mm
Rim Diameter: 18 in 457.2 mm
Rim Width Range: Unrecognized tire size.
Overall Diameter: 28.86 in 733.04 mm
Sidewall Height: 5.43 in 137.92 mm
Radius: 14.43 in 366.52 mm
Circumference: 90.66 in 2302.7 mm
Revs per Mile: 720.7
Old 01-25-2011, 05:15 PM
LSOHOLIC's Avatar
Maybe you meant to say 315/40R18 ?? Which is a NT05R size, if not where did you find a 345/40R18 tire. And who makes it ??
Old 01-25-2011, 05:27 PM
TooMuchMoney's Avatar
Long story short my buddy tried doing the same exact thing as your trying to do and now he has 315 on it. Like Lsoholic said it just wont work.
Old 01-26-2011, 05:10 PM
jkz06's Avatar
Like everyone else said you need a 12 to 13 inch wheel to fit. If the rim is not wide enough you will not get anymore contact patch from a 345 than you would a 315. The 345 would have about an inch on each side that would never wear out because it would never touch the ground.
Old 01-26-2011, 06:34 PM
V-seriesTech's Avatar
mini tub'd here...homemade G
Old 01-26-2011, 07:17 PM
WKMCD's Avatar
Maybe we need a translator here so it can be said in 7 or 8 different languages..
I'll start with English.......Won't work!
Old 01-28-2011, 12:32 PM
VT_Z06's Avatar
My 335/30/18s required a mini-tub. So...I don't think wider AND taller would work, without work.
Old 01-31-2011, 05:23 PM
Spd-Kilz's Avatar
Ca ne marchera pas.
Old 01-31-2011, 09:30 PM
1BADBURB's Avatar
Actually, a 335/30/18 fits without minitub. I have ccw classics with just the right offset, that it fits snugly.
However the op listed tire, that's a BIG f'n tire. 345/40/18 is tall as **** and will NOT fit under even a stock height vette.
Aj
Old 02-03-2011, 05:45 PM
JoeyGC5's Avatar
I occasionally run M&H 345/35/18 Dr's on my 2.75" mini-tubbed Vette and they just barely rub on hard suspension jolts.
Quick Reply: 345/40/18
