Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Clunk, knock, thump, rear, diff, trans and bump.
Old 03-10-2009, 08:25 AM
DAVID@VASPEED's Avatar
Default Clunk, knock, thump, rear, diff, trans and bump.
Figured since I just got finished hunting for a strange noise in the rear of my C5Z I would make a thread with some of the keywords cause I had very little luck when searching the forums. I was getting a Clunk, knock, thump from my rear, diff, trans on my 2003 C5 Z06. It turned out to be a backed off axle nut, I applied loc tite and tightened and it cured it. This caused a very light clunk when changing gears at the moment you release the clutch. Ok, I hope this contains enough keywords that anyone else having this problem can find it.
David
dave@vaspeed.com
Old 03-12-2009, 03:29 PM
Jedi Master
Gh0st's Avatar
David
dave@vaspeed.com
I get this in my GTO all of the time. All my bolts look fine, I'm lost
Old 03-12-2009, 08:09 PM
Corvee's Avatar
Could be that your need differential fluid additive.
Old 10-19-2011, 11:57 PM
bvbyce's Avatar
i have this problem too, slightest clunk, i'll have to check for something loose, what else could it be?
Old 10-19-2011, 11:58 PM
bvbyce's Avatar
wow, old thread, nobodies coming back to this one
Quick Reply: Clunk, knock, thump, rear, diff, trans and bump.
